Previous in Forum: Earthing Resistance   Next in Forum: Question About IC Connections (UDN2917EB - Stepper Controler)
Panel Assembly
06/09/2010 10:30 AM
I was asked by my client to assemble a 200A distribution panel, which will consist of 20A MCB to be control by an external switch.
I want to know is there any control switch that can operate 20A MCB without opening the panel to put on or off the MCB?
Good Answers: 58
Re: Panel Assembly
06/09/2010 11:25 AM
Did you mean "which will consist of a 200A MCB" instead of a "20A MCB"?
Assuming that you meant "200A MCB", then yes, using a larger tub, you can install a 200A, 3 pole contactor after the over current protection device ( the 200A MCB) which will serve the same purpose controlling the MCB.
If you did in fact mean a "20A MCB" you will have to provide more detail. I am not aware of a 20A MCB being installed in a 200A panel?????????
Re: Panel Assembly
06/09/2010 3:45 PM
Depending on exactly what needs to be done, a shunt-trip circuit breaker or motorized-operator circuit breaker could be what you asre looking for.
Good Answers: 804
Re: Panel Assembly
06/09/2010 8:54 PM
Typos and acronyms, never a good mixture...
If you are truly referring to a 20A MCB (Mini Circuit Breaker), then yes, the Merlin Gerin line of MCBs has a through-door lockable operator handle accessory.
If you were referring to 200A MCB (as in Main Circuit Breaker) then every brand I am aware of has external operating mechanisms available as options.
Re: Panel Assembly
06/10/2010 9:32 AM
Are you a Dar engineeer
Good Answers: 170
Re: Panel Assembly
06/10/2010 9:53 AM
If it is MCB, then Switching OFF without opening the door is very much possible with a shunt release fitted on to the MCB and controlling the supply to the shunt release with any external switching device. But, I very much doubt if remote ON facility is commercially available for MCBs.
In case of MCCBs, yes! both Remote ON & Remote OFF are possible with Motorised Operators & Shunt Releases.
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: Panel Assembly
06/12/2010 5:49 AM
jus use a rotary handle for mcb or mccb.......u can easily turn on/off.....it s the simple n cheap way......
shamith gambhir, electrical engineer
Anonymous Poster (1); electricalexpert65 (1); JRaef (1); KJK/USA (1); SHAMITHGAMBHIR1 (1); Tornado (1)
You might be interested in: Control Panel Services, Switch Boots
