Hi all,
I'm a little bit confused with the diagram provided in the datasheet of this IC:
1) On page 1, under maximum ratings, it says: Pin 5 "E1 - Output emmitter voltage"... 1.0 V
Is this a voltage I need to supply, or an output? what exactly is this pin doing?
2) What is the function of SENSE(4), Vref(44), and ENABLE(42)?
Furthermore: I know that the input "PHASE" controls the direction of
the current through each coil, but where is the input to actually
energize each coil? ie: where do i connect my parallel port outputs, to
make the controller send 'steps'?
Thanks,
