Previous in Forum: Freeze The Oil Leak   Next in Forum: '99 Dodge Transfer Fuel Pump Flow
23 comments
Equivalence
06/12/2010 4:42 PM
Good day,
I sent a piece of metal 94.00 grams to Montreal Polytechnique to get an analysis on silver and gold. Here is what I received:
CU mg/L 170,0 AG mg/L 65,8 AU mg/L 65,9
Is there someone that can translate this result in % of the weight or in grams?
Thank you in advance.
H. L.
"Most of the important things in the world have been accomplished by people who have kept on trying when there seemed to be no hope at all"- Dale Carnegie
Re: Equivalence
06/12/2010 4:59 PM
What was the volume of the submitted piece? From there it's just arithmetic.
Re: Equivalence
06/12/2010 6:15 PM
Tornado,
I do not know the volume.
You mean the displacement of water after the peace of metal is introduced in a liter?
If so, I do not know.
Thank you for answering.
H. L.
Re: Equivalence
06/12/2010 7:47 PM
Hubert, it looks like the analysis was done by AAS (Atomic Absorption Spectroscopy). These numbers should convert directly to ppm. This means that there is 170ppm copper (0.17%), 65ppm silver (0.065%), and 65.9ppm gold (0.0659%). I would assume that if you are in the mining industry that there would be tin and nickle as the balance, but that is just a guess.
If these numbers look way off, then you need to call up Polytechnique and find out how much of your sample they dissolved, and how much liquid they used in the analysis. Next, you divide the mass (in mg) by the volume (in L) to get your total ppm.
To change this to percent, divide the metal analyzed value by the total value. Lets use some numbers to make this a little more clear.
Sample dissolved: 300 mg (this value needs to be in mg)
Final total volume sample is dissolved in: 0.250 L (this value needs to be in L)
300 / .250 = 1200 mg/L or ppm
65.9 mg/L gold / 1200 mg/L total = 5.5% gold in your sample.
Re: Equivalence
06/12/2010 7:50 PM
Same guest as above.
The numbers that you received should be already standardized to the amount of sample used. This means that the number should be correct as it stands.
Re: Equivalence
06/12/2010 9:06 PM
Thank you GUEST,
Yes, the analysis was done by Atomic Absortion.
I spent 25 years in precious metal recycling and this is the first time I received a result in mg/L. I will call up the Université de Montréal monday.
You may have a good answer but I still think there is more gold because I melted it myself.
But we never know...
Hubert
Good Answers: 32
Re: Equivalence
06/14/2010 9:41 AM
The conversion of ppm to percent is incorrect. To convert ppm to %, you divide ppm by 10,000. So 170 ppm is 0.017% etc.
Re: Equivalence
06/14/2010 11:03 PM
You are correct Tad, I guess that will teach me for writing a technical response while I am in a hurry.
And to the person modding everything as Off Topic, SOMETHING IS NOT OFF TOPIC IF YOU DO NOT AGREE WITH IT!
-the guest from above
Re: Equivalence
06/12/2010 8:41 PM
I am surprised that the lab expressed their report in mg/L units, which are more suitable for substances in water. Until we know some densities, we don't know what a liter of metal weighs. Conversely, we don't know from 94 grams what the volume of the sample was. If the sample was irregularly shaped, putting it in a graduate of water and comparing the difference in readings would give the volume.
Converting mg/L into a fractional equivalent such as ppm or percent requires dividing by the density involved.
Good Answers: 120
Re: Equivalence
06/12/2010 11:43 PM
well, they need to answer in better terms than that. This is not a proper assay report. How much did they charge? or was this a freeby student assay?
if this was 3 ounces of gold = over $3000 worth if pure.
What is the purpose behind this assay?
Why not use an assay company.
there are many of them, use your country, and look for mining +assayers
Per Ardua Ad Astra
Good Answers: 61
Re: Equivalence
06/12/2010 11:49 PM
Since they found only copper, silver and gold, we must assume that is nearly 100% of the metal. Ignoring any trace elements present, the ratio of Cu to Ag to Au is 170:65.8:65.9. It doesn't matter how much sample was taken or how much solution was made from it, only the ratios of the concentrations are relevant. The composition of your metal is therefore:
56.35 % copper
21.81 % silver
21.84 % gold
Is this about what you expected?
Re: Equivalence
06/13/2010 12:23 AM
The percentages of Cu, Ag, and Au are much less than that. Enough clues are here on the thread to figure out why.
Re: Equivalence
06/13/2010 2:58 AM
I'd like to assume that apart from Copper, Silver and Gold that piece of metal contained other stuff that is not considered interesting. Also, that the whole lump dissolved completely in whatever quantity of solvent that was used to dissolve it (and/or that the lump is very homogenous and/or the sample taken from it is very representative).
If so, the lump contains: 0.18085% Copper, 0.07011% Silver, 0.0700% Gold and 99.67904% other stuff. All percentages being by weight.
Or am I wrong too?
Constant change is here to stay!
Good Answers: 120
Re: Equivalence
06/13/2010 7:39 AM
A typical lab would weigh the sample, and if it was a cast sample and showed no stratification would dissolve a small representative sample in aqua regia.
If you look here you will find test procedures in the links.
http://www.alsglobal.com/mineralDownloads.aspx
google assay labs, there are many more.
Per Ardua Ad Astra
Good Answers: 61
Re: Equivalence
06/13/2010 9:58 AM
There is nothing that tells us anything about the concentrations of elements in the original sample, only that 94 g. of the metal sample was submitted. Some, or all, would have been dissolved in aqua regia and analysed by AA (ICP is also a possibilty). Whether the resulting solution was diluted to 10 litres or 100 litres is irrelevant, the AA analysis merely gives us the ratio of weights between the 3 elements found in the solution. If there were other elements present in large quantities then that should have been reported - otherwise the assay is useless.
Re: Equivalence
06/13/2010 4:23 PM
Other elements don't matter for AA. it only tests for the specific element that you tell it to, and gives back the concentration in the liquid tested. Cheaper AA can only test for one element at a time, but the more expensive ones can test for 3 or more during each run.
Re: Equivalence
06/13/2010 5:26 PM
Thank you Guest.
The mystery should be resolved tomorrow.
Hubert
Re: Equivalence
06/18/2010 6:34 PM
Hello all,
The technician at Polytechnique is on vacation until June 29.
I will have a ICP analysis next week and I let everyone hnow a correct answer and at the end of June, I hope I will have the comments from the technician who did the test.
Thank you to all of you .
Hubert
Good Answers: 32
Re: Equivalence
06/14/2010 9:53 AM
This is an obvious error by the lab. No lab would report concentrations of a solid in mg/l. You will have to call them to get the correct answer.
The problem probably occurred by having one technician prepare the sample (dissolve and dilute it) while another technician analyzed it by AA. Someone should have taken the concentration, and calculated the actual concentration in the original sample. Instead, it looks like you got just the concentration from the tech. that analyzed the diluted sample.
You can not even assume that the ratios of concentrations in the original sample match the ratios of concentrations given. The sample may have been split, and different dilutions used for different analysis.
Re: Equivalence
06/18/2010 1:58 PM
Ja. Right, Tad. All correct !
Ha, ha.
Ha, ha.
Re: Equivalence
06/14/2010 8:54 PM
Your analysts gave you raw experimental data which can be interpreted as follow:
Cu, Ag and Au exist in your sample at ratio 170:65.8:65.9. or 2.57:1:1.
So, in your 94g of metal,
You have Cu as Cu=170/(170+65.8+65.9)x94=52.97grams
Ag will be 65.8/(170+65.8+65.9)x94=20.50grams
Au will be 65.9/(170+65.8+65.9)=20.53grams
Check: 52.97+20.50+20.53=94grams
When you can express what you are speaking about mathematically, then you really know something about it.
Good Answers: 61
Re: Equivalence
06/14/2010 9:21 PM
Erm - This is merely a rehash of my entry.
Good Answers: 61
Re: Equivalence
07/10/2010 12:20 PM
"The technician at Polytechnique is on vacation until June 29.
Thank you to all of you ." ......... Hubert Lefebvre
Well June 29th has come and gone, but still no results from you. When are you going to put us out of our agony?
Re: Equivalence
07/10/2010 4:07 PM
Her answer will be on this site within 2 days.
Thank you "Energyconversion" for still remembering.
Hubert
Register to Reply 23 comments
Anonymous Poster (4); aurizon (2); dovy (1); energyconversion (4); Hubert Lefebvre (5); ICPEAR (1); Tad (2); TOPE (1); Tornado (3)
