I need to help one of my neighbors in a conflict with the power company:
He bought a house where with the registration of the meter was tampered with.
When the seller had problems himself when the company detected how he was doing
it, my neighbor became under suspicion too.
He has many 3 phase meters, fed out of current transformers.
The meter had been remotely switched of while they still were using current.
Now the company measured the phases, disconnected the heaviest phase (most amps)
runs 2 meters at each point in parallel.
1 electronic version and the old mechanical one on 2 phases (they disconnected one) continuous.
The reading differences are resp. 36%, 55% and 200%.
The difference should be used to determine the amount of "tampered current". to be used as figure to go back in time to calculate the fine.
The company found it a nice peace of tampering, although I don't share that opinion.
I had the opportunity to study the situation and the "fine investigation setup" is totally different from the actual "take". It has been discovered when switching meters from
conventional to GPS assisted Electronic version, where the power company can know
before you when you tamper.
I don't care about the initiator, but my neighbor has been set up for a max. 22% power take (profit?- theft?) without his knowledge and according the figures he will need to pay at least for 100% too much.
How is the metering been done in these meters? 2 wires per CT? A power line for the
meter also? He made an appointment and I can use all there is available of good advise.
Thanks
