In the first attempt to cap the Deepwater Horizon spill, methane hydrate accumulated on the structure and prevented the cap from being used as intended. My question is, could a plug be designed to shape the accumulating methane hydrate into a spike of the right dimensions to fit the pipe.
For example, here's my basic sketch of a "hydrate popsicle maker". A heavy plug which also contains an internal power source to (a) take in some seawater (b) heat the water to a point that would melt methane hydrate, and (c) pump the warmed water out in a ring of jets that are angled to form a taperiing spike of methane hydrate, customized to the pipe by control of the jets' warming action.
Why would this or wouldn't this work? What problems would you anticipate and can the design idea be adapted to resolve those problems? (for example, you might need additional heat output to prevent hydrate from covering the water intake). If this design has already been discussed elsewhere, link me up. Thanks.
