Previous in Forum: Difference Between T91, T23, T21 Materials   Next in Forum: Conductivity of Heat Through Copper?
Anti Rust Coating for Nails
06/16/2010 12:43 PM
Can some one suggest a anti rust coating for nails manufactured by us.
As you see from the picture , the nails that we manufacture are used in a nail gun for nailing wooden boxes etc.
We are looking for solution which could be either with water based system or solvent based system of rust preventive coating. The desired colour shade is bright golden shade with a glossy appearance. It shud be quick drying and have min 5 microns coat thickness with a life of at least 1 year.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: Anti Rust Coating for Nails
06/16/2010 1:09 PM
Give me enough duct tape and I can fix anything!
Good Answers: 119
06/16/2010 2:19 PM
Have you researched any of the common adhesive/cement coatings which improve grip strength and could also inhibit corrosion ?
Good Answers: 49
06/17/2010 1:31 AM
Why not make the nails out of aluminum? Harden it if there is any concern about deflection, but I suspect that plain old aluminum (or a simple alloy) will work just fine.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
06/17/2010 3:50 AM
This doesn't meet your colour requirement, but, have you considered packaging with VCI paper.
06/17/2010 5:26 AM
The ones I used 35 years ago were coated with some sort of hard glue.
This softened and glued the nail to the wood when it was fired in due to the heat of the friction (devil of a job to remove, it was as strong as screwing) and the glue (plastic maybe?) protected the nail before and after usage from rusting....
I understood at the time that this was the normal way to stop such nails rusting!!
06/17/2010 5:27 AM
Have you considered that a nail is actually SUPPOSED to corrode (oxidize) a little on its' contact-surface with the surrounding material? Only this provides the actual bonding, much the same as with rebar in concrete: rust is required for bonding on a micro-level, but the oxidizing process should stop after the available oxygen is used up.
Don't worry, be happy.
Register to Reply 6 comments
Andy Germany (1); energygod (1); farmatt (1); fredart (1); mjb1962853 (1); Randall (1)
