Previous in Forum: Single Lane Private Bridge   Next in Forum: Importance of Uniformity Coefficient
United States - Member - Proud to be a part of this Great Nation
Will Pure 90-Degree Sheet Metal Bend Produce Invisible Cracks?
06/17/2010 9:57 AM
In the process of forming either 10 or 12 gauge plain steel sheet metal bends (from 90 degrees up to 180 degrees), will the convex side of the bend (tension side) produce cracks or other deformations invisible to the naked eye? Please assume that the bends work in concert to established punch radius-to-metal thickness ratios.
After the bent material is properly washed of deleterious materials, which would inhibit good paint adhesion, the item is powder coated. However, after the powder coating process is complete, sometimes the paint appears not to bond as well at the bend radius, as well as it does on the adjacent flat surfaces. For your information, we typically do not use galvanized sheet metal or primered sheet metal which is going to be powder coated. I suspect that invisible deformations occur on the tension side of the 90 degree + bend, as a result of the bending process. And that these deformations are causing the paint to not bond well to the steel substrate.
I'm no metallurgist, but in reading some of the physical changes that occur in cold-forming metal and within steel's elastic limit, the tension strain along the bend may cause some particle dislocations. I'm thinking this may be the cause for the poor paint adhesion directly on the bend. If this is the problem, would a simple coating of primer be the solution?
~Research Is Something I Do When I Don't Know What I'm Doing~ Wernher Von Braun
Re: Will Pure 90-Degree Sheet Metal Bend Produce Invisible Cracks?
06/17/2010 10:22 AM
"If this is the problem, would a simple coating of primer be the solution?"
Sure, why not.
One thing not discovered on your other thread... how many days pass between the fabrication of these pieces and coating? Stress crack will reveal white metal, and will begin to corrode immediately. Should rust bloom be considered as the culprit?
06/17/2010 7:45 PM
A 180° bend is a seam used to reinforce an edge on thin sheet metal. For a 180° bend, I would form the edge over a minimum 1/4" dia wire.
Mr.Ron from South Ms.
Good Answers: 150
06/17/2010 11:51 PM
Maybe, depends on the steel in question and it's properties. But you should also consider the way powder coating is applied. It is applied without a primer, and it is electrostatically sprayed on the part. Sharp edges dissipate static charges much more than gentler bends will, and since the electrostatic charge in that area is diminished, less powder will stick to that area.
Who is John Galt?
06/18/2010 6:46 AM
"... sometimes the paint appears not to bond as well at the bend radius,...)
Well, If this is happening only sometimes, it means that the cleaning process or preparation is lacking sometimes! Also, when bending there will be some distortion and if the bending apparatus is properly set, there should be no cracks, otherwise re-set. What will happen is that the surface in that area will be smoother (more than the flats) and maybe a small amount of rubbing with a fine brush... before cleaning will help reduce the incident of bad adhesion.
06/18/2010 7:20 AM
Short answer is yes - plastic deformation is a certainty if the sheet metal stays in that shape after forming - cracking is unlikely. However, I agree with a previous poster than the coating failure is more likely caused by the edge effects of the static charge field and the natural tendency of coatings to pull back from edges and thin out (regardless of the coating technique - this is true of brush and roller, too). You might try priming the edge or stripe coating it prior to coating the bulk of the surfaces, or you might be able to deal with this by improving your process control on the powder coating when working near the edges.
06/18/2010 1:58 PM
I can answer this but R4 blocks my answers
Former steel research engineer
PEbobimm
06/18/2010 9:44 PM
You might talk to the finishing trade folks. www.pfonline.com will get you to the right discussion groups and experts if you don't find an answer here.
Register to Reply 7 comments
Anonymous Poster (2); Doorman (1); jgjengr (1); LAA_Lucke (1); ronseto (1); Rorschach (1)
