Previous in Forum: Vacuum Sensor Failure   Next in Forum: PLC and SCADA Systems
Float Type Level Indicator
06/21/2010 4:55 AM
Can you anyone idea that float type level indicator work in vaccum tank.
Re: float type level indicator
06/21/2010 5:01 AM
Is the vacuum strong enough to boil the liquid?
What is the liquid, the temperature and pressure?
06/21/2010 5:19 AM
A vacuum has no effect on the laws which govern bouyancy.
So I'd say, any level indicator that will work in the tank when it's not pumped down.
06/21/2010 5:34 AM
Further - is the float itself rated for full vacuum?
06/21/2010 5:28 PM
full vacuum?
Shirley that's a contramadiction of the wordifold?
The vacumold is truly the emptimost not the fullitrope of the content.
06/22/2010 12:38 PM
No, folly, folly. The vacuum-suckers and squeeze it is the basey fundamold of the problode.
Go thorkus over a pie and a pint of keggy bruflame.
Re: Float Type Level Indicator
06/23/2010 3:03 AM
A level control that works very well in refrigeration surge drums is the Sporlan Level Master LMC series expansion valves. I don't know if the vacuum will have some effect on the probe, since it uses a heater to evaporate a fluid in the sensing bulb. The heat conductance changes when the liquid level covers the bulb as opposed to when it does not. There is a change in volume with the change in state from liquid to vapor, and this applies pressure on a diaphragm. In turn, this opens or closed the expansion needle-seat valve. For a price, I suppose, the fluid in the sensing bulb and capillary tube could be selected to suit your process. It would have to be a compound suitable for the temperature range your liquid level will be.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
Coldspot (1); PWSlack (3); user-deleted-1105 (2)
