Previous in Forum: Accurate Chlorine Sensor   Next in Forum: Data Logging
Water Disposal
06/23/2010 3:49 AM
Hii,
Ref to above mentioned fig, this scheme is used for water disposal to lift station, water comes from Hydrocarbon storage tank, This sump tank is typically 2.0M in Height, I would like to know how water gets lifted from this pit and travels another 5-8 M to Lift station W/O any pump or other element
Regards
Jose
Re: Water Disposal
06/23/2010 10:40 AM
the graphic is too small to be able to read.
Re: Water Disposal
06/23/2010 1:31 PM
If 1) the pump has once been primed, 2) the level controls work properly, and 3) there are no leaks in the check valve and pump suction piping; then the pipe from the sump to the pump will remain full of water, and the pump will remain primed. The water is pushed into the pump by atmospheric pressure.
Re: Water Disposal
06/24/2010 4:33 AM
More information is needed. What is downstream? Does it have some form of positive displacement pump, ejector, or vacuum-generating device?
Re: Water Disposal
06/24/2010 5:37 AM
If it is a sealed tank with oil coming in on top of the water, the lower density of oil will ensure it floats and pushes don the water. This has to get out through the drain pipe reaching to the bottom of the tank.
The driving force is the pressure of incoming oil.
Bioramani
bioramani
Good Answers: 179
Re: Water Disposal
06/24/2010 9:09 AM
By siphon action, as long as the dischage pipe reamins full and "primed".
Signed,
CaptMoosie, LPE/PhD
Re: Water Disposal
06/26/2010 12:35 AM
Thanks for all the info
Regards
Jose
Re: Water Disposal
06/24/2010 11:26 AM
Is the idea to ensure that the hydrocarbon storage tank is always full without any vapour space on top as a precaution against explosions? In which case the water is used as a higher density mobile tank bottom. It just keeps going in and out of the tank to an over head retaining tank. Bioramani
bioramani
Register to Reply 7 comments
Anonymous Poster (1); bioramani (2); CaptMoosie (1); josej (1); PWSlack (1); Tornado (1)
