Previous in Forum: Mechanical Properties of Glass?   Next in Forum: Pipe Sizes
13 comments
Immersible Low Temp Heater
06/28/2010 2:47 PM
I am looking for an immersible 110V heating element to keep a low% alcohol solution at 40C. It has to be able to run dry as solution will evaporate (glass won't do). I have tried hot water tank heating elements but the ones I have been able to obtain do not have enough temp control i.e. too hot. Any suggestions.
Thanks
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: Immersible low temp Heater
06/28/2010 2:53 PM
How about an aquarium heater?
Give me enough duct tape and I can fix anything!
06/28/2010 7:53 PM
sorry glass won't do explodes when solution evaporates below it's element
06/28/2010 2:57 PM
If you use a 480 volt element at 120 volts, it will draw 1/4 of its rated current and produce 1/16 of its rated wattage. Then, if the fluid evaporates, the watt density of the element may be low enough to keep it from overheating. Further, it could be controlled by a solid-state heater control, which in effect modulates the voltage to maintain a nearly constant temperature.
06/28/2010 2:58 PM
Ask a moonshiner
Re: Immersible Low Temp Heater
06/28/2010 8:07 PM
Metal immersion cup heater, with a timer or power limiter? Who knows? You don't even give any idea of scale.
06/28/2010 11:04 PM
Nice. Add a thermostat controlled switch and you are in business. You clever devil.
06/28/2010 10:56 PM
Aquarium heater in water. The heater heats a glass container full of water that is placed in the larger container of your alcohol solution. Keep the water topped up. Let the alcohol evaporate.
06/28/2010 10:59 PM
Ignore my previous reply. Most aquarium heaters top out at 35 degree C.
06/28/2010 11:08 PM
As already mentioned by someone else- you have not mentioned the volume, kind of container etc etc. Are you looking for controlling temperature in a small cup or is it a huge tank of hundreds or thousands of liters ? Temperature controllers are available to maintain 1000Deg C+/- 0.5 Deg C. So what is your specification / requirement?
06/29/2010 12:23 PM
To accurately control the heat you would need to the submersible heater, temperature feedback, and a controller with the high-limit cut off to keep from burning up the heater when the solution evaporates. This is a very common industrial application. With accuracy and control comes cost, so if you are looking for a quick, low cost solution, you will sacrifice the accuracy and control. We specialize in heat and can you. If you like, call Andy at E&M Sales at 303-979-5000.
06/29/2010 9:18 PM
Why submersible? Why not an element under the container?
Then light bulbs could be used, varying the wattage to suit needs, possibly with a high-temperature cut off in ,or on the tank for when it runs dry.
Sounds kinda like a covert distiller to me.
Good luck.
06/30/2010 9:59 AM
I already said "ask a moonshiner"
Canada - Member - New Member
06/30/2010 12:30 PM
Try Watlow they make heaters for most aplications.
www.watlow.com
Good Luck.
Knowledge makes what was impossible, seem easy.
Register to Reply 13 comments
Andy@E&MSales (1); Anonymous Poster (2); Elroy (1); farmatt (3); Happy Fish (3); jaydub (1); lyn (1); Tornado (1)
