Previous in Forum: VFD and Motor Power Calculation   Next in Forum: Earthing Without Salt, Cu, Coal
AC With 125kva DG
06/30/2010 7:55 AM
How many 2 ton AC does a 125kva gen. Set can power?
Re: AC With 125kva DG
06/30/2010 9:13 AM
Power can set. gen 125kva a does AC ton 2 many how.
07/01/2010 9:21 AM
Window the in doggie that is much how?
Tail waggly the with one the.....
Good Answers: 101
07/01/2010 9:26 AM
Master Yoda!!!! Shame on you!!!! You keep reprimanding me for playing pranks on people and now you're mocking someone else's English when your's is no better!!!!
01/24/2023 9:59 AM
A prosecution for the third apostrophe is not out of the question...
06/30/2010 9:50 AM
Usually Generator will deliver maximum efficiency at 0.8 Load Power Factor. The design of the generator should be such a way that, it must carry 20% over load. So, the Generator can carry 125 x 0.8 x 1.2 = 120kW
You refer the AC manufacturer's Literature and find the kW rating of the AC unit. Usually 1ton is taken as 1.25kW. I don't know, whether in your side it is correct. Then, you count the number of units to reach 120kW
Assistant Electrical Inspector, Govt. of Kerala, India
06/30/2010 8:38 PM
Thank you sir i am a B.Tech fresher from kerala.
Anonymous Poster (2); DVader1000 (1); PWSlack (2); user-deleted-1098 (1)
