Previous in Forum: 3-days extensive Workshop for Engineers is announced   Next in Forum: Job in libya
11 comments
Light Ray
07/02/2010 11:34 AM
"Light is an electromagnetic wave" but why it will not deflect in electrical and magnetic
fields...?
Arise, awake and stop not still the goal is reached.....
Pathfinder Tags: light and electromagnetism
Re: Light Ray
07/02/2010 11:59 AM
I think you are confusing electromegnetic waves with beams of electrons.
Other electromagmetic rays, radio, radar, microwaves etc behave similarly.
Beams of electrons or other charged particles will deflect in electrical or magnetic firlds.
Good Answers: 204
Re: Light Ray
07/02/2010 10:35 PM
because they have zero rest mass. Why is salt not harmful to us, even though it is sodium and chlorine. The components of light are perfectly locked together, and are immune to the fields.
Re: Light Ray
07/03/2010 3:33 AM
Kindly study Hubble telescope experiments to study Einstein's theory. Light beam gets deflected under gravitational forces of heavenly objects. For example Earth can behave like a heavenly lens (as per Einstein's theory deflecting Sun' s rays - may be seen from Pluto or beyond solar system.
May be if you have electric fields or magnetic fields like that in space - small deflections to light rays could be studied- till then it will be a academic questions and an academic answer.
Re: Light Ray
07/03/2010 11:03 AM
Here's a somewhat simplistic answer, but it hits the key points of your question, I think:
The momentum of a photon depends only on its frequency (or wavelength) [E = hν]. To deflect a photon you'd have to change its momentum, which means your magnetic field would have to change the frequency or wavelength of the light.
On the other hand, the photon's spin angular momentum does not depend on frequency, so a magnetic field can affect the (circular) polarization of a beam of light.
Re: Light Ray
07/03/2010 1:25 PM
Electromagnetic fields don't interact with each other directly but do interact with charged particles (matter) which can act as a intermediary. Thus you have electo-optical effects such as Pockels and Kerr effects.
Engineering Fields - Optical Engineering - New Member
Re: Light Ray
07/05/2010 5:05 AM
EM wave is like a moving/changing/oscillating EM field with E&M fields perpendicular to each other. So when an EM wave encounters another E or M fileld, the interaction of fields modify the local field in the interacting volume/area.
Good Answers: 204
Re: Light Ray
07/05/2010 2:05 PM
so just to carry this a bit deeper...
Q: WHY does light bend when it enters materials with a different refractive index?
A: Because the speed of light is different in that Material.
Q: WHY is the speed of light different in materials with different refractive indices?
A: Because the atoms are closer together?
Q: If the light ray is interacting with atoms, how can it still continue in a straight line?
A: Because interactions with the atoms does not show unless the photon is absorbed. otherwise, it is the electric and magnetic fields that the photon is travelling in that are affected (compressed) by the atomic fields.
what?? that can't be right.. you are making that sh*t up...
okay fine, I am... but what else could it be? light is only composed of an electric and magnetic component... so both must be affected together to alter the apparent velocity... so somehow.. oh hell I don't know.
Re: Light Ray
07/05/2010 11:21 PM
I have doubt about your first statement that light is fundamentally an electromagnetic wave. For example infra red light is a heat wave - not a electrostatic / electromagnetic wave !!! Light- visible / invisible etc etc - has been shown in a spectrum of wavelength - starting from near zero- then acoustic wave and then radio waves etc and then invisible and visible light and beyond. You also have acoustic waves - which definitely is not a EM wave !! Entire wave spectrum is NOT EM wave.
So first check your statement about light being a EM wave.
Good Answers: 204
Re: Light Ray
07/05/2010 11:54 PM
James Clerk Maxwell just rolled over in his grave.
Re: Light Ray
07/06/2010 4:21 AM
You have no idea what you are talking about, you are confusing the frequency with the actual type of wave. You can make a spring or a piece of string oscillate at an audio frequency, it doesn't make it electromagnetic wave, an acoustic wave or anything else. It's a mechanical wave, maybe longitudinal transverse or whatever. Throw a stone in a pond, that will propagate a wave.
Similarly you can have an electromagnetic wave at audio frequency (it won't be very usefull, except for maybe submarine communication)
You need to understand more before you throw you paper hat into the ring.
Good Answers: 32
Re: Light Ray
07/07/2010 9:54 AM
Interaction of electric field that of photon is possible in medium at interfaces and only up to short distances.
Electromagnetic waves and even x-rays of high energies can bend in special conditions.
Don't expect them to bend using a magnet as wave is pure energy. You have to deform its field to interact with.
Register to Reply 11 comments
Anonymous Poster (2); chrisg288 (3); g srikanth (1); Rixter (1); Shyam (1); Usbport (1); user-deleted-1105 (2)
You might be interested in: Light Emitting Diodes (LED), Light Guides
