I forgot my password.
Don't have an account?
Dear All
I did lot of search about pipe hanger for clamping roof steel I-beam to vertical pipe. All what i have found is pipe hanger for horizontal pipes?
Does anyone Know if this product exist.
Thanks in advance
Check the product in the lower right corner of this view:
http://www.anvilintl.com/ProductSearch/ProductThumbnailView.aspx?plid=106&ptid=592
The two bolts closest to the middle are used to clamp to the pipe. The outer two bolts are used to attach to two hanger rods with beam clevises at the top.
Hope this helps.
what i understood from your description and the picture of the hanger is there will be
additional connection between the beam bottom flange and the hanger clamp which is
not what i am looking for
Anyway appreciate your help
I too started by thinking of a riser clamp. Some further ideas might be found at http://www.vikinggroupinc.com/en/products or http://www.grinnell.com/
