Previous in Forum: Fertilizer Spreader   Next in Forum: Vertical Pipe Hanger
54 comments
Centrifugal Pump Minimum Flow
07/04/2010 12:10 AM
Dear Engineers,
I want to know how to find out a Centrifugal pump Minimum flow from the pump charecteristic curve if it is not specified in the pump Data sheet
Thanks,
G S Basha
Good Answers: 141
Re: Centrifugal Pump Minimum Flow
07/04/2010 12:12 AM
Send a copy, someone here will certainly pick up the thread.
Plenty of room here
07/04/2010 12:23 AM
Look at the curve. This is a random curve.
07/04/2010 12:53 AM
If the pump curves show the NPSHr at various conditions, the minimum flow rate will occur where the NPSHr (plus maybe a safety factor such 2 feet) becomes greater than the NPSHa. A basic curve may not be sufficient.
Location: Move between Pakistan, Singapore, UK, and Canada
07/04/2010 2:21 AM
It depends on your application. In most of the cases you shouldn't be using at a flow rate less than 50% of the B.E.P. It's not just the characteristic curve, you should also have some idea where it is being applied. For more details check this out : http://www.pumps.org/content_detail.aspx?id=2138
Other factors that might affect this can be
-Temperature rise of the liquid
-Radial hydraulic thrust on impellers
-Flow re-circulation in the pump impeller
-Total head characteristic curve
Check out ANSI/HI 9.6.3-1997 Centrifugal and Vertical Pumps - Allowable Operating Region for more recommendations
07/04/2010 2:54 AM
These are all good points--GA. The 50% of BEP is a familiar rule of thumb, especially if the pump curves do not include NPSHr curves.
Good Answers: 97
07/04/2010 2:25 AM
For the best answer you must give more detail.
But you seem to be in a position where you might not have control over the flow.
A Centrifugal pump, pumping cool water should be able to run with a closed valve (zero flow) for a short period of time. But one of the main problems with running a centrifugal pump with a closed valve is heating. Energy is fed into the pump and will cause heating.
The pump shown above have pipes from the volute to the bearings for cooling.
Because of the placing there should always be a flow to the bearing but the temperature may rise above limits.
The NPSH may also change due to temperature.
But you will have to watch temperature's.
A practical solution would be to place a pressure relief valve on the discharge side with a backflow to the sump.
The valve should be set above the design head but below the closed valve pressure.
If this setup provides for sufficient cooling you may run continues.
But giving more information would be better.
Good Answers: 58
07/05/2010 2:31 AM
Pipes from the volute go to the lantern ring in the stuffing box - not to the bearings.
There are usually orifice plates in these lines and the flow would normally be too low to maintain thermal stability of the pump.
07/05/2010 4:52 AM
I thought more for "Mechanical Seal"!
Stuffing Box system must be adjusted so that there is a drop-leak to lubricate and cool the shaft. Usually that should be enough.
Mechanical seals need cooling in some cases and I tought this type of feeding back was for that Only....Please correct me.
Good Answers: 27
07/05/2010 5:16 AM
Stuffing box will only leak if the suction pressure is greater than atmospheric, hence the need to supply cooling fluid at a higher pressure to the lantern rings in the stuffing box. This serves to cool, lubricate and prevent air ingress.
You are correct, the same holds true for mechanical seals if fitted. This would be an API plan 11 and would serve to maintain the seal chamber pressure above atmospheric pressure and to dissipate the heat generated by the seal faces.
I have no special talent. I am only passionately curious. Albert E
07/04/2010 2:49 AM
Zero is generally the minimum for most things.
Good Answers: 38
07/04/2010 3:00 PM
Basha...
The only definitive source of information on minimum flow is from the pump vendor.
This is because there are mechanical issues ( shaft defelction...excessive bearing loadings) as well as heat build-up issues that also control the determination of a minimum flow
Generally speaking, single stage centrifugal pumps have a lower % minimum flow than multi-staged pumps. The pumps with the highest minimum flow requirements are multi-staged boiler feed pumps and the similar de-scaling pumps used in steel mills.
Since you probably do not have any documentation for this used pump, you will have to rely on a rule of thumb from someone.
The HI standard mentioned below is a good place to start.
Did you bother to GOOGLE your question before you came to this forum ?
What did you find out during your search ?
07/04/2010 11:12 PM
Minimum flow is zero. Assuming you shut off the outlet or have a very long vertical pipe, the pump develops a maximum pressure. The fluid in the casing just gets churned and heated. pump will not be damaged unlike a positive displacement pump. Bioramani
bioramani
07/04/2010 11:18 PM
"pump will not be damaged unlike a positive displacement pump"
Sorry, but your information is incorrect. The centrifugal pump will definitely destroy itself. If you deadhead the pump, there's no place to dissipate the heat energy.
07/05/2010 4:40 AM
A centrifugal pump has a continuous passage from inlet to out let. The velocity head is converted into pressure head.
Unless the inlet has a one way valve (The OP did not give any layout) the pump will not be damaged.
Bioramani
bioramani
07/05/2010 9:17 AM
I don't know where your head is, but it must be really dark there. You are still wrong.
If inlet and outlet are blocked there is no flow, now way for heat to escape. Pump fails. End of story!!
07/05/2010 11:41 AM
With all respect to you, I did say 'unless there is a check valve'. The curve that you have provided above has a value of zero flow at dead head pressure. A flooded suction centrifugal pump with no check valve takes quite a while to heat up once enough vapour is produced the pressure developed drops quite a bit. It does not blow up like a positive displacement pump pumping an incompressible fluid. bioramani
bioramani
07/05/2010 11:53 AM
Sorry, the curve was generic. I'm not talking about explosions, I'm talking about pumps building sufficient internal heat to destroy themselves.
This discussion (OP) has nothing to do with PD pumps. You first introduced the subject of PD pumps in your post #9.
Up to that point, the discussion had been confined, properly, to centrifugal pumps.
Sorry If I offended you.
07/05/2010 11:58 AM
usually those pump curves ends before "0" flow.
07/12/2010 4:46 AM
Zero flow is one of the required points when testing API 610 pumps and is a required point on the curve. One reason for this is to see whether the curve rises continuously to Shut off as required.
Generic families of curves obviously do not show this point.
07/16/2010 12:00 PM
No offence given, none taken. In fifty one years of work I have used many centrifugal pumps (mostly anticorrosive simple open impeller ones; mostly metallic) for various aqueous chemicals. Dead heading was not an unknown occurrence. Did not have any heat related problems even once. However 15 HP was the highest power I used, which is not high enough to boil the two to five litres water in the casing too rapidly. I still feel that even if the liquid boils, all that can happen is that the casing reaches about 100 C and vapour lock happens. The pressure developed will then drop quickly. The drive motor may go to a virtual no load condition, which may cause some problem for the motor if allowed for long. Other than that no great harm can come. I can do a trial the next time that I go to the company R&D division. Bioramani
bioramani
Good Answers: 196
07/16/2010 12:30 PM
Bioramani- This is really a good answer. Your voice of experience counts here.
A minor point is that overheating to the boiling point in a chemical pump may create other problems due to higher corrosion rates with some chemicals at high temperatures, stuffing box /mechanical seal distress or drive coupling alignment issues due to unexpected thermal expansion.
Ed Weldon
07/16/2010 12:40 PM
You are right. Though many alloy pumps are designed to handle hot corrosive solutions. Probably I should have qualified my first post as for the case of short duration dead heading. Usually in a flooded suction situation without a non return valve the problems are minimal. Bioramani
bioramani
Good Answers: 27
07/19/2010 3:33 AM
As you point out, the short term problems of running at shutoff are related to catastrophic failure of seals due to dry running. As vapourisation of the pumped medium takes place, the point of highest temperature is at the seal (or packing) faces. If the seal then fails, the vapour that has formed in the pump due to the increase in temperature is very often a flammable one. Loss of containment is a very serious issue in many plants.
The long term issues are more to do with damage to seals and bearings due to high axial and radial loads due to non-ideal hydraulic behaviour within the pump at low or no flow. This leads to a reduction of the time between maintenance.
Running a centrifugal pump at very low flow or shutoff head is without question, something to be avoided.
07/05/2010 9:20 AM
Thats is true, we at deadhead centrifugal pumps at times with a modulating valve to control flow.
07/05/2010 11:22 AM
Blockheads like myself have proven that many centrifical pumps CAN be dead-headed, but no one would recommend making the this a habit. Fortunately for us, the designers must try to make installations blockhead-proof.
I am talking about the times a pump is started and nothing comes out the discharge at the other end of the pipe, wherever that may be. However, one broken shaft or blown pipe seal would ruin a day, and maybe more. Check, check, and check valves again. Walk the line to the end without taking your eyes off of it.
Right or wrong, in the engine room I have restricted flow by 'choking-down' the discharge valve - sometimes to decrease flow (for proper delta T for instance) or to limit cavitation (or the noise I thought was cavitation).
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
07/05/2010 11:39 AM
I'm talking about continued zero flow conditions. There's no place for the built up heat to go.
However, some of my former customers, after insisting on oversized pumps have destroyed them by restricting, not dead heading, the flow of the pumps. These vertical pumps were completely submerged in a sump and still destroyed themselves. The liquid in the sump was very hot, too. They were not metal pumps, so I should have qualified my remarks.
But for someone to insist that dead heading a pump won't hurt it is ridiculous.
07/05/2010 11:54 AM
Was commissioning an Ultrafiltration unit. Our company went through 4 control engineers (all different issues) writing the code and the code reflected it at the time of commission, of which we had no control engineers.
When we did the fist continuous run, we had a sensor fail, that made it a closed looped process, and with the heat generated when just pumping is quickly noticeable as the chart recorder showed (on a different process), but coupled with running it through the membranes, we smoked $30,000.00. worth of membranes. Turned out the high temperature cut off was disabled in the program.
I just want to clarify, Periodic dead heading can be done without issues. continous dead heading can be a problem.
p911
07/05/2010 12:02 PM
Too many cooks spoil the soup.
I agree, momentary dead heading USUALLY won't hurt a centrifugal pump.
07/05/2010 1:15 PM
We had one electrical engineer, who everyone, especially the customers, was accusing for being an alcoholic, but was not, but was a diabetic. the other 3 were hired to finish the job.
I had called the companies engineer before he was canned, and talked to him saying things are turning brown, and word is his a$$ in on the blocks, it may be too late to shape up. only then did he reveal about his health issue. Which pissed me off, something like that, we could have easily planned and worked around it.
Yes too many cooks.
Good Answers: 18
07/19/2010 2:08 AM
Ditto Lyn, only idiots will dead head a pump continuously. In fact some "operators" think they can save enrgy by not switching off the pump and then ONLY shut off the valve, avoiding frequent on/off. However, as in my tenure as engineer at a yeast plant, 24hrs deadhead makes a Sulzer volute go bang.
Always learning
Good Answers: 18
07/05/2010 2:35 AM
The fluid in the casing just gets churned and heated. pump will not be damaged. This is the sad part of this forum, or any other forum for that matter. The OP started his post "dear engineers", and then somebody writes this drivel. He is obviously not an engineer.
The liquid will heat up against a closed valve, and if left to churn, it will explode due to excessive pressure. Anybody that have seen a blown volute will know. Even if it does not explode ( leaking seals, maybe) it will destroy itself.
Always learning
07/05/2010 3:50 AM
Under most circumstances, this is incorrect, although it can be true in unusual circumstances.
The worst problem occurs if liquid is trapped in the pump by closed upstream and downstream valves (or check valves). This rare scenario could heat up the trapped liquid, leading to hydrostatic expansion and possible rupture after a period of time. If the liquid can flow back into the suction, or through a relief valve, no such excessive pressure will occur.
The churning of static fluid will indeed heat it, as Bioramani mentions. This might cause a seal to leak, or even boil the liquid back through the pump suction. But again, if the liquid is not blocked in by closed valves in both directions, there will be no harmful rise in pressure.
This differs from positive-displacement (gear, vane, piston, screw) pumps, in which closure of a discharge valve will cause abrupt pressure rise.
Your statement is much too alarmist and dogmatic, and not particularly knowledgeable.
Good Answers: 18
07/05/2010 4:24 AM
of course not, only gurus seem to be.
Always learning
Good Answers: 196
07/04/2010 11:12 PM
gsbasha -- SimS gave you a good generic answer in #4. If you want some specific info tell us more about the application you have in mind since running a centrifugal pump at low flow can have substantially different consequences depending on the size, specific speed and impeller diameter relative to available maximum impeller diameter of the pump as well as the system head curve of the piping with respect to the proportion of static head to friction head. Also if you have a specific pump on a specific system in mind tell us as much as you can about it.
Generally the larger the pump the bigger will be the issues of inefficiency and bearing loads from operating near to shutoff. In small fractional HP pumps these issues become trivial compared to the initial procurement cost of the pump. And note that it doesn't take much actual flow to carry away the waste heat absorbed by the water in the casing of the pump.
Another thing to be aware of is operating a pump with rising head -capacity curve at low flows on a system with mostly static head can invite surging as the pump hunts between two close possible operating points.
Ed Weldon
Good Answers: 49
07/04/2010 11:45 PM
As alluded to in earlier posts- there is DEFINITELY a minimum flow.
If you do not have the pump curve, assume an efficiency of 50% (likely at low flow) - meaning that 50% of input energy has to make heat. The minimum flow would be whatever is required to keep whatever flow is occurring from being heated more than about 10F.
Example- a 20 HP motor at 50% efficiency generates 50% X 2545 BTUH per HP X 20 HP, or 25,450 BTUH. That thermal input, divided by 10F rise is 25450 / (8.33 pounds per gallon X 60 minutes per hour) or 5.1 GPM. That is the absolute MINIMUM flow. To be safe, I would double that to ease the burden on the likely metal-ceramic seals, so consider minimum flow for a 20 HP motor pump to be about 10 GPM.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Good Answers: 27
07/05/2010 3:41 AM
Some good comments.
Minimum stable flow for pumps (bad kitty ) is based on either hydraulic stable flow and or thermal stable flow. Low flows have the folling negative effects:
  • Temperaure rise due to internal energy loss
  • Internal Recirculation
  • Increas in NPSHr
  • Vibration due to flow separation
  • Pressure fluctuations or pulsation
  • Increas in axial thrust
  • High radial forces
The single most important number associated with stable flow is Suction Specific Speed. (Nss or S = nQ 0.5/NPSHr 0.75 )
In the '80's Richard Dubner (Chevron) did a lot of research on the reliability of a large sample of pumps and came up with the graph below. Note that it is based on the suction specific speed of the pump at Best Efficiency Point with the maximum diameter impeller. Note also that you can go to much lower flows in hydrocarbon service than with water. In the absence of anything else, this is as good a guide for minimum stable flow as you are likely to find. When in doubt err on the side of higher flows.
NPSHa must at all times be higher than NPSH required (by around 1 meter generally).
Graph of Minimum Continuous Flows
Figure 1. Dubner's (Chevron) Chart for Minimum Capacity
"Note that Figure 1 cautions against S values greater than 11,000, and prohibits operation of any pump larger than 100 gpm (BEP) from operating continuously at less than 20 percent of BEP.
This graph may be used to establish operating guidelines for existing pumps, and in the selection process for new pumps to eliminate offerings that have a minimum flow above that anticipated for the intended service."
Lobanoff & Ross also give some guidelines with the below figure. Note how as the Nss increase, the operating range of the pump gets smaller.
The second thing that needs to be looked at is the minimum safe thermal flow. This is the one that wrecks pumps and seals quickly as opposed to the stable flow which is more of a reliability issue.
In order to calculate the temperature rise the following is proposed by Sulzer
deltaT = H x 0.00981/c x ((1/eff)-1) where c = specific heat and H = head
Sulzer also concludes that the following is adequate to specify an allowable temperature rise (choose a temperature rise that is reasonable considering the vapour pressure etc of the pumped fluid, material of seals etc - where vapour pressure is not a consideration Sulzer uses 20 deg C which I consider far too high)
Q min = Power x 3600/(density x specific heat x temperature rise)
Power in kW, specific heat in kJ/kgK, density om kg/m3 and temperature rise in degrees C.
07/05/2010 6:33 AM
Dear all,
Can someone confirm the folllowing for me: Is Static Head only applicable in Open systems? For example in a closed system (tank, pump and recirclation loop) does the static head actually matter since the liquid on the pump discharge side is being "pushed" by the liquid on the suction side. If this is correct then is the head only a result of the pipework friction (which is a result of the flowrate). Thank you in advance for your input.
John
07/05/2010 9:09 AM
Yes. Static suction head and static discharge head will be the same.
07/05/2010 2:11 PM
NOT TRUE!!
Consider your cardiovascular system, which is a closed system. If your systolic pressure is equal to your diastolic pressure you have been dead for some time and your heart is not beating.
Where . . . have all the engineers gone . . . ?
Little about much, much about little
07/05/2010 3:16 PM
They are still arround these engineer!
But your comparison does not stick as an example: Systolic diastolic pressure are not Static pressures! The previous remark was about static pressures only (I think).
Therefore, find another example and try to be more accurate so that we could follow you. Thank you.
07/06/2010 2:18 AM
fjdomingues,
"Where . . . have all the engineers gone . . . ?" how ironic given your answer. Are you actually an engineer? I somehow doubt it. I am guessing that you are either a hairdresser or work as a manager in McDonalds.
07/06/2010 2:48 AM
Oh dear!
07/05/2010 11:32 AM
By my way of thinking a closed system has a static head - the pressure existing in the system without the pump running.
An open system has by definition a static head proportional to the height of the liquid in the expansion tank.
Good Answers: 18
07/06/2010 2:21 AM
Static head is the height which a pump can pump to. It is actuall y the pressure exerted on the system prior to delivery.
Always learning
07/06/2010 2:49 AM
Your two statements are mutually contradictory.
07/06/2010 3:09 AM
Jvrj: YES! You are absolutely right. Static head – after the pump is turned on – is the height which a pump can pump to.
Energygod introduced the work 'dynamic'. That as well refers to after the pump turns on, and more correctly – DYNAMIC STATIC HEAD.
I think Guest in #21 was ruminating about the pressure that exists in a system before the pump is turned on - it is the true static head ON THE SYSTEM. In an open system it is the height of the water above the pump, in a closed system it is the pressure exerted on the diaphragm of the bladder expansion tank or the air in a conventional expansion tank.
The problem is when THIS static head is insufficient when the pump starts. If the suction pressure on the suction side of the pump is pulled down below the vapor pressure of the fluid being pumped we get cavitation.
After the pump starts we call the suction pressure on the suction side of the pump Net Positive Suction Head (NPSH), because it had better positive (I guess) or the fluid boils – cavitation.
One must analyze the phrase "Suction Pressure". Even though there is suction, there still is pressure. It might be negative, but it is still pressure.
In our bodies the difference between systolic and diastolic pressure it the true DYNAMIC STATIC HEAD pressure produced by our hearts. The true static pressure of or blood – a closed system – is greater than atmospheric pressure, and that explains why the blood leaks out when we cut ourselves.
Fortunately blood has a higher vapor pressure than what the suction pressure gets pulled down to when our heart beats. If it didn't our blood would boil.
My blood often boils, but due another reason.
Must get back to work, but this is more fun.
07/06/2010 3:30 AM
Static head is when nothing is moving; it is just the difference in elevation between where the pump is pumping from and where it is pumping to. After the pump turns on, static head no longer applies alone; it is now dynamic head (things are moving). At this point you need also to consider pipe friction losses, and also velocity head at the smallest cross-sectional area in the piping system. The term for all of these is "total dynamic head", or TDH.
07/12/2010 4:55 AM
Total dynamic head plus static head = Total head.
Good Answers: 18
07/06/2010 3:53 AM
Delivery was brought into my statement MEANING the point at which the pressure escapes ( or ends its journey under pressure. The end of the pipe, out of the pipe, now in a tank or dam. ie. the pump has done its job, whether its 3 meters or 30 meters.
Always learning
Good Answers: 27
07/12/2010 4:51 AM
"Static head is the height which a pump can pump to"
I guess this is not what you meant to say. Static head is a system head - it has nothing to do with the pump.
Good Answers: 18
07/12/2010 5:10 AM
Thank you,
Always learning
Good Answers: 49
07/05/2010 3:27 PM
The only "watch-out" is a possibility that the combined static and dynamic pressures might exceed pump volute or seal failure pressure. If that happens, you hear a POP and have a big mess plus non-functioning system to deal with until you buy and install a new, stronger pump.
07/05/2010 4:34 PM
the pump should give (mod/ser plate) the gpm's and rpm's, i think at minimum flows, the siphon may break, and cavate on the suction side of the pump.
Good Answers: 117
07/19/2010 2:09 AM
post a copy of the data sheet for all to see please
Register to Reply 54 comments
Anonymous Poster (5); bioramani (5); brich (1); Coldspot (3); dvmdsc (1); Ed Weldon (2); energygod (2); FJDomingues (1); Hendrik (1); jvr (1); jvrj (6); Kaisan (4); LAA_Lucke (2); lyn (6); MJCronin (1); munch (1); phoenix911 (4); SimS (1); The Prof (1); Tornado (5); user-deleted-1105 (1)
You might be interested in: Centrifugal Pumps, Gas Flow Meters
