Previous in Forum: VGA AMale to 3-Component Video Male Cable   Next in Forum: How Many Aerosol Cans Will Fit into the Bin?
11 comments
What Lab Apparatus is Used to Make Water from H and O?
07/11/2010 7:15 PM
I've seen electrolysis many times, but I've never seen the set up or apparatus which could be used to synthesize water. What would it be ? Is electricity or heat used, or high pressure ? There's likely more than one method, I would guess. Would someone explain them or show me ? What was going on when the vast quantities of earth's water was being compounded ? Thanks.
Good Answers: 29
Re: What lab apparatus is used to make water from H and O ?
07/11/2010 7:22 PM
I think all you have to do is burn hydrogen which ignites quite readily. The reaction gives off heat (exothermic) and yields Water (H2O) by combining molecular hydrogen (two atoms) with one oxygen atom.
I'll have to think about the lab apparatus
Si vis pacem, para bellum
07/11/2010 7:26 PM
A mixing nozzle, a match, and a condenser for the resultant steam? 2H2+O2→2H2O.
Good Answers: 176
Re: What Lab Apparatus is Used to Make Water from H and O?
07/11/2010 10:02 PM
Definitely not lab scale, the Hindenburg approach is an large scale H2 + O2 conversion technique:
Good Answers: 119
07/11/2010 11:49 PM
See...
http://en.wikipedia.org/wiki/Oxyhydrogen
Chemistry lecture hall, first day 1980: Chem professor takes an empty 5 lb coffee can with plastic lid on top and 1 small hole in the metal bottom. He fills it with hydrogen gas from a small tank. He positions the can on a table with metal (with small hole) side up and places an ignitor near the hole. A nearly invisible small flame starts as the lighter hydrogen gas escapes from the hole, mixes with air, and burns. At the same time, air (and oxygen) is entering the can to replace the escaped hydrogen. As the professor lectures on about stoichiometric ratios of fuel and air, the mixture inside the can reaches the correct ratio of hydrogen to oxygen and
BOOM!
The internal mixture of 2H2+O2 is quickly converted to steam and the can rockets almost to the 40 ft. ceiling of the lecture hall. Some student were frightened, but most applauded a very effective demonstration. This chemistry professor knew how to captivate and engage his students for the rest of the semester. Good luck trying that in our current vacuous and litigious environment
Good Answers: 22
07/13/2010 7:46 AM
You'll be pleased to know my lecturer did this a couple of years ago - but he left the lights off and just had us sitting in the dark watching the pretty flame until..... BOOOOM!!! Great start to the lecture. Maybe we're less litigious down this end of the world??
07/12/2010 9:32 AM
Almost any source of ignition will do it, from an electric spark to a lighted match.
Apparatus Used to Make Water from H2 and O2
07/12/2010 10:16 AM
There is a piece of equipment designed to do this; Hydrogen Fuel Cell.
Here is a factsheet regarding the general operation of them. Google will reveal many, many hits on the subject.
Re: Apparatus Used to Make Water from H2 and O2
07/12/2010 1:59 PM
Very good. Instead of an explosion, resulting a lot of wasted energy (unless used in an ICE), the fuel cell effects a controlled reaction with output in the form of electrical energy.
Good Answers: 146
07/12/2010 4:34 PM
And here's a biotech version of a hydrogen fuel cell...
Ralstonia metallidurans enzymes are cheaper than platinum...
incus opella
07/12/2010 11:16 PM
Overall maintenance costs?
Good Answers: 146
07/13/2010 7:22 AM
maintenance... the article said they could only keep it working temporarily - don't know if they've found a solution for that yet.
incus opella
Register to Reply 11 comments
artsmith (2); Doorman (1); Iris (1); Mikerho (2); mjb1962853 (1); PMoon (1); PWSlack (1); RobertOz (1); Tornado (1)
