Previous in Forum: What kind of filter media is most suitable for removing oil from seawater?   Next in Forum: Transmitter/Receiver
Making of Concentric Reducer
07/16/2010 3:39 PM
i would like to make a concentric reducer by using a papper or plate could u send me that?i would like to know the formula to make the reducer
Re: Making of Concentric Reducer
07/17/2010 12:25 AM
Not enough information disu. The internet is not a magic box.
Do you mean something like this:
What is papper?
What formula is there to know? Just manufacture it to the dimensions it needs to be.
07/17/2010 5:48 AM
sir for temporary i need to make a reducer in 2mm thick stainless steel plate how can i fabricate it?is there any method to make a concentric reducer in a stainless steel plate?that is what iam asked to you?
07/17/2010 3:20 PM
sir i want tofabricate a concentric reducer in a 2mm plate i want to make lay out in the plate . is there any theory to mark in the plate?
07/17/2010 8:17 PM
Dimension thus:
D = larger diameter (as in Mikerho's drawing)
d = smaller diameter (C in same)
h = height of reducer (B in same)
Extend the upper and lower edges of the reducer until they meet at a vertex.
H = perpendicular distance of vertex from center of D; = Dh/(D-d).
R = slope distance of vertex to either end of D; = √[H2 + (D/2)2].
r = slope distance of vertex to either end of d; = Rd/D.
Then the piece of metal you need is an annular sector of outer radius R, inner radius r, and angle 180D/H
[Ordinarily this would not be done via formulas. Instead one would use the drafting techniques for developments and intersections.]
Register to Reply 4 comments
Anonymous Poster (1); disu (1); Mikerho (1); Tornado (1)
