Previous in Forum: JCIS Fasteners   Next in Forum: Design Challenge/Problem: Rubber Bumper Testing
Bearing Nomenclatures
02/28/2007 11:19 AM
Does the number/nomenclature on a bearing tells the speed limit it could withstand? If yes, how do I select a single roll ball bearing for a speed up to 24000rpm?
Best Regard
Ashiru D.
Re: Bearing Nomenclatures
02/28/2007 11:27 AM
As soon as I've seen in internal market, bearing nomenclature and part numbers change with manufacturer, although they may be interchangeable.
I recommend you to look at some suppliers catalogs to determine the candidates to meet your requirements. You'll note that the larger the bearing, less speed it can withstand. Take a look if you don't need any other feature like self compensation, sealed, high temp, heavy duty, vibration, dirty environment... Some features must be chosen for the right bearing type. Some of them will influence the expected life limit. You will also check it in the catalog.
In my place, for specific applications, you can even call a rep for help without any aditional charge.
Humm... suspicious you are...
United States - Member - New Member Engineering Fields - Military Engineering - Member Engineering Fields - Mechanical Engineering - New Member
02/28/2007 3:48 PM
Agreed, lots of manufacturers' have online application guides. Ideally, type in roller bearing into globalspec's search, find a company that meets your design requirments; then check with the suppliers website to see if they have any technical references or application guides.
02/28/2007 9:47 PM
Needle bearings are better than ball bearings. The temperature they will run at is just as important as the speed. High speed bearings do exist, grinding machines run at up to tens of thousands of rpm. Also centrifuges need to run at prolonged high speeds.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Fans of Old Computers - ZX-81 - Computers: I spend HOURS saving time with them.
02/28/2007 11:40 PM
single row ball bearings for high speed or high heat applications typically have marginally smaller balls to allow for heat expansion. Most manufacturers include this information as a suffix to the part number. a 6204 bearing made for normal usage will have a c1 or c2 rating, and this is not normally included in the part number. c3, c4 and higher classifications are normally indicated as a suffix to the part number. A typical SKF part number goes something like 6204-2Z C3. They are common in electric motors.
The Universe is made up of parts
03/01/2007 1:11 AM
From the number of bearing,there are no speed info in it.
For your application of speed up to 24000rpm with single roll ball bearing,It will be used in electric-axial or motor of grinding machines.
It has special mumber/nomenclature in manufacture catalogue.
william.bei
03/01/2007 4:30 AM
Look up all info relating size+ maximum operating speed+ max load at Interactive SKF Catalog:
http://www.skf.com/portal/skf/home/products?paf_dm=shared&maincatalogue=1&lang=en&newlink=3
By the way--you cannot read out speed limits from Bearing No. But sizes-YES(mostly)
Register to Reply 6 comments
bhrescobar (1); BrainWave (1); cmnky26 (1); MUKULMAHANT (1); partsman (1); user-deleted-1114 (1)
