Previous in Forum: Diameter Factor in Worm Wheel   Next in Forum: Spiral Bevel Gear Scuffing
India - Member - New Member
Hoist Testing
07/22/2010 7:12 AM
We were testing the hoist designed for 5 t but at 900 kg started sliding and the load remains at the same height.
Expert opinion for the root cause is requested.
With regards,
Nilesh.
Pathfinder Tags: Hoist Testing
Re: Hoist Testing
07/22/2010 7:19 AM
The hoist failed the test.
Re: Hoist Testing
07/22/2010 7:29 AM
That;s true but, can you tell me possible root cause for this failure as the Hoist was Installed since last 1 year before it was tested due to no approch to the area dut o scaff hOLDING ETC...
Itwas tested in presence of Local authority.
Regards,
Re: Hoist Testing
07/22/2010 7:43 AM
Something has changed since the original test was carried out. Find out what it is and fix it.
Re: Hoist Testing
07/22/2010 7:27 AM
<...Expert opinion for the root cause is requested...>
Then why not let that expert witness the test?
No-one on CR4, apart from the original poster, has seen the test!
Good Answers: 29
Re: Hoist Testing
07/22/2010 10:39 AM
Nor will any responsible responder offer you any advice that will lead you to avoid any safety issues involved with such a test.
Re: Hoist Testing
07/23/2010 12:32 AM
Please describe the hoist.
If it is an electrically powered drum winch, the motor brake might be slipping, or something may be blocking the brake from engaging.
If it is a hydraulic unit, a valve might be leaking by, or a cylinder piston seal may be leaking.
Your description of "started sliding and the load remains at the same height" is inconsistent.
Register to Reply 6 comments
Anonymous Poster (1); Nilesh (1); PWSlack (2); RDGRNR (1); Tornado (1)
