Previous in Forum: Inudction Furnaces   Next in Forum: Boiler Tubesheet Repair
11 comments
Bakelite
07/24/2010 10:51 PM
Can Thermo set materials duplicate the old Bakelite material
is it possible to get the formula for Bakelite
if you had the formula could you run it in the USA
Pathfinder Tags: Bakelite
Re: Bakelite
07/24/2010 10:58 PM
Yes.
Yes.
Yes.
Didn't you just ask about this last week?
Re: Bakelite
07/24/2010 11:03 PM
not for the formula for Bakelite - the questions differ - Thanks
Re: Bakelite
07/24/2010 11:15 PM
As you might suspect, the "formula" for Bakelite is probably protected.
It is not difficult to duplicate. There are many thermoset materials that are roughly equivalent to the original formulation.
It has also been copied by people who try to pass off the copied resin as real.
What is your reason for asking?
Re: Bakelite
07/24/2010 11:07 PM
were can i get the formula and and were can i buy the powder to make jewery
Re: Bakelite
07/24/2010 11:19 PM
Re: Bakelite
07/25/2010 8:09 AM
Thanks for the information - have some Bakelite - it is diferent to the touch,smell, sound, trying to come up with a new old line - it is new but has the feel of 1950 Bakelite - question again - is there a Bakelite press or was it all in the Die -
Re: Bakelite
07/25/2010 9:16 AM
" is there a Bakelite press or was it all in the Die" We'll have to define terms.
To me, in this context a "die" is a split metal piece, with the half the cavity in each side. The cavity is machined to mold the piece of plastic into near net finished shape, with maybe some cleanup required at the parting line of the die. I prefer to use the term mold.
The press is the machine that holds the die and heats it to cure the plastic under pressure. It is fitted with hydraulic rams which hold the mold closed during cure. So, in order to produce a piece of jewelry, you'd need both.
I guess it would depend on potential sales, but there must be someone making an equivalent product. Maybe a Chinese company. They are known to copy about everything else.
Re: Bakelite
07/26/2010 7:20 AM
The Bakelite patents were originally from a company called Durez in North Tonawanda, New York. Durez was bought out by Hooker Chemical which was bought out by Occidental Petroleum. I do not know the status of the patents but you could start with this information at Occidental and maybe they could help. The formulations should be on record with them.
Good Answers: 203
Re: Bakelite
07/25/2010 11:12 PM
Try-
http://www.chemindustry.com/apps/chemicals
http://www.bakelite-delight.com/gpage.html
http://adsabs.harvard.edu/abs/1992mdss.rept.....V
Bakelite is a very old material so its formula can probably be found with some various internet search engines.
Also, I remember making this material is freshman or sophmore chemistry lab in college. That was over 45 years ago so your search is probably more history than scientific/patent orientated.
Good Luck
Old Salt
Re: Bakelite
07/26/2010 1:31 AM
I remember making it as a high school project, just over 50 years ago. Unfortunately, the only ingredient I remember is carbolic acid, and I have no idea of the concentration...
Re: Bakelite
07/27/2010 5:59 AM
There is a good article on Bakelite in Wikipedia.
Register to Reply 11 comments
Anonymous Poster (1); cal1159909 (3); dkwarner (1); lyn (4); old salt (1); PWSlack (1)
