Previous in Forum: Magnet Energy   Next in Forum: why we are still manufacturing energy inefficient filament bulbs
Mechanical Project
07/27/2010 3:00 AM
I want final year project ideas for mechanical engineering.
Re: mechanical project
07/27/2010 3:40 AM
In material handling it is often desirable to raise a tote or drum to some height and then tip it to pour out the contents. There are various kludgy two-step methods for doing this. Your mission, should you choose to accept it, is to devise a one-step actuator to do this. This tape will self-destruct in the next ten seconds....
Re: Mechanical Project
07/28/2010 2:39 AM
What do the course tutors have to say on the topic?
India - Member - New Member Germany - Member - New Member France - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Engineering Fields - Energy Engineering - New Member Hobbies - RC Aircraft - New Member
07/31/2010 4:43 AM
hi u can make a small wind turbine(50-60watt) to charge a battery which will give back up when grid supply is Interrupted.
or u can go for mecha electronics project like small car with camera & radio control.
if it is hard then tell me i will give u another simple solution.
one more thing here i m giving a site for free Ebook download
http://www.archive.org
Be an engineer not a degree holder!
08/03/2010 3:47 AM
thank you for your suggestin sir , i will be greatfull if you can suggest me another ideas too.
11/16/2010 7:06 AM
Hello prakash qupta,
A combustion engine having no pistons no mechanical assistance and only one moving part when one ways are excluded.
Early model of this compression ignition engine was no further pursued as developers moved on to recycling Carbon Dioxide turbine generator to out deliver elctricity 300 hundred fold against a Steam turbine without increase in heat.
Engineering Blue print is available.
Cheers
Peter
Anonymous Poster (1); DaS Energy (1); PWSlack (1); rajeshbhanushali123 (1); Tornado (1)
