Previous in Forum: Koken Barber Chair Brake   Next in Forum: Maintenance Manuals for Mitsubishi and Fuji Ozone Generators
CAT 3516 Crankcase High Pressure Trip
07/27/2010 10:27 PM
Hi can anyone help me , we are running a 3516 genset on an instalation in thailand , it is very humid , the engine is exposed to the sea with little cover , exept overhead , the engine mainly trips at night 456 am .???????????
Re: CAT 3516 Crankcase High Pressure Trip
07/28/2010 2:14 AM
What does the genset manufacturer say on the topic?
Good Answers: 60
07/28/2010 6:10 AM
read the instruction manual, and is there a drop/rise in barometric presure at that time?
is the crank case vent clear.
But manufactures should know,
set up a camera to vido the area and record whats happening at or about that time, just in case there is somthing else setting it off.
07/28/2010 11:00 AM
"...mainly trips at night 456 am"
Does this mean consistently trips at 4:56 A.M. local time?
Seems as if there may be a clue here... hmmmm.
Good Answers: 60
07/28/2010 11:16 AM
possibly a local who doesn't like the noise, animal interference set up a hide (camouflage hut) and wait with video camera to see what happens at this time.
08/04/2010 10:47 AM
I have to assume this is an electronic engine, if you have a communications adapter and software you can access the engine ECM, check for codes, see what the shut down is set for and see what the crankcase pressure is running at, verify it with a manometer, You can also check codes and the run time of event with the Cat generator Controller. I had some gensets with crankcase ventilation devices to take the oil mist out, they were installed improperly and caused the gensets to shut down, I also heard of an engine that shut down repeatedly, it restarted every time except the last one where it exploaded. No warranty recorded in the ECM.
Doorman (1); norton850 (1); peterg7lyq (2); PWSlack (1)
