IML is the abbreviation of In-mould labeling, is a totally new package style that is different from the traditional of direct silk-screen, thermal contraction tag, adhesive sticker tag, which is popular in the Europe and America, and keep lingering in china for more than two years, not it have the wide use with the large scale.
IML is mainly used in making the PP, PE, PET injected molding and blowing molding products. That is, put the tag into the blow or injected cavity before blowing or injecting, and when the mould closed and the material go into the mould, the tag and the surface of products will be one part through high temperature and pressure, when the mould is opened, the good printing products will come out.
The IML solution line includes IML special mould, high speed injection machine, vale-gate hot runner system and IML robot. At present, for all I know, only have only several companies are able to produce 30ml thin wall product mould with 16 cavities and 5s/shot. Meanwhile, the least wall thickness for thin wall products is 0.4mm.
The Advantage of IML
1. The characteristics of IML could directly improve the security functions of products, which could satisfy the needs of high-criterion and brand protection.
2. The exquisite packaging, and the specially good effect, such as laser and aluminizing could be realized, which improve the level of the products package.
3. The outstanding and creative layout, hard to break, waterproof, grease proofing, and mildew proof.
4. The security and health of packaging products could be improved, and meanwhile, the IML prevent from print and pollute the environment twice.
5. The lower cost.
As we know that every coin has its two sides, including the IML.
1. If you would like to make the IML products, what you have to prepare is the special injection machine.
2. The tags need the special print machines as well.
