Previous in Forum: SA376 vs SA312   Next in Forum: Covert Cartesian Coordinates Into Cylindrical Coordinates
9 comments
Caulk? Or Something Better?
08/06/2010 6:02 AM
Please help me identify this corner sealing and finish material - look at the overall view, and then upper and lower details at right [more below pictures].
Pictured at left is pan and stitch image of . . . I'll call it, adhesive sealant moulding, used to finish the corner junction between the wall on the left and the window style on the right. Except at the top and bottom (and yes, stitching has caused distortion of the panned image), the alignment and thickness of the "moulding" is remarkably uniform . . . suggestive of the appearance of a drywall junction tape imbedment application. At the top and bottom of the moulding installation (pictured at right) can be seen evidence of manual manipulation applied to "finish off" application of the material. Whether this material comes in the form of a workable
"tape," or is extruded and applied into the corner is not apparent to me; and if the latter, I am unfamiliar with any ordinary "caulking" tool able to (so uniformly) apply "beads" of the pictured width [1 inch (+/-)] and thickness. For those interested in seeing the material first hand, the pictures were obtained during Rx pickup while waiting at the consultation window of my local Costco pharmacy.
I observed the material - whatever it is - to display physical qualities which could solve a longstanding, intractable problem with water intrusion into a wall cavity of our house:
  • Very tough skinned yet pliable
  • Very high tack and resistance to peeling or removal
  • Seems to be permanent in every sense of the word.
  • Obviously would be impervious to moisture penetration or bypass.
The only uncertainty might be its "performance" and durability when exposed to sun rays and the elements in exterior, unsheltered environments. But, I sense that the material could withstand just about any interior or exterior environment for a very long time. In some ways it is reminiscent of a . . . faux stucco/masonry material I sometimes see in the exterior walls of new buildings here: it looks and feels like hard stucco, but when pressed it is pliable . . . as if it was rolled on or sprayed (precolored or painted afterward), as opposed to requiring setting and curing in the case of "true" stucco. Perhaps that material and the within finishing sealant share some constituent materials in order to have such similar properties?
My basic question, then, is: can anyone advise what the (obviously commercial grade) material is called? And where it might be obtained? And with what tools it is typically applied? Or is it supplied in tape roll form? I would assume based on my observations, that the material could be applied to just about any exterior material . . . be it painted or unpainted wood, vinyl, metal, or even masonry or stucco. I would also guess it is expensive . . . more than even the best home center caulks; but it it stops our persistent winter water intrustion and the resultant damage, it would be worth it.
BTW, I did check with Depot and Lowe's but they could offer nothing similar, and no familiarity . . .
Thank you.
Re: Caulk? Or Something Better?
08/06/2010 7:05 AM
This is polyurethane caulking. The width of the bead suggests that someone "goofed" big time on a measurement during construction, and it was probably allowed because the store was opening the next day, or something. The primary supplier in the US is Sikaflex. You can find this at Home Depot, it comes in self leveling, (for concrete expansion joints in driveways, sidewalks, etc.), or non-sagging, seen here. It comes in oversize caulking tubes, for which an oversize gun must be purchased. This bead was actually very labor intensive. The applicator probably taped off both sides, applied multiple beads of caulk, and then tooled it with either mineral spirits or soapy water to achieve this result.
Good Answers: 266
08/06/2010 8:10 AM
It's most likely polyurethane chalk the size of the bead to cover the fact the window is too small for the opening as Kramarat suggests.
There are many manufactures of polyurethane chalk. Our company does installations of windows. We do testing on the products we use our choice is XtraBond 9500. Has good bonding properties, is non yellowing, extrudes at low temperature 0° F.
We do commercial properties multi-family housing low odor was a big point has no solvents.
08/06/2010 8:33 AM
I have seen that one also. I brought up Sikaflex, because it sounded like he wanted to buy some. It is available at Home Depot, unfortunately, the employees rarely know what they have or where it is. It's not by the caulking, as you would suspect, but tucked away on the side of the store with the sand, concrete, etc. The oversize guns will be found in a completely unrelated section of the store, again, not by the rest of the caulking. ( I guess I should throw out the warning to the OP, that if you are unfamiliar with caulking, this stuff can quickly become a big sticky mess).
Good Answers: 266
08/06/2010 1:00 PM
We had to address the odor some of these sealants give off while curing. Never used Silaflex so unfamiliar with it. Some of these sealants with solvent base can be quiet strong. We found those with health issues might have a problem. Some just complained about the smell. This was our solution. Just thought to give an alternative in case.
Note do not recommend any that have a rough texture to them. Though they might work well as a sealant. The rough texture will gather dust and dirt in it. Rain washes the air clean of particles as it runs down the rough textured chalk it collects it. They need to be cleaned regularly. Those that are smooth will not hold the dust.
08/06/2010 1:20 PM
I'd like to give it a try. Is it polyurethane or some type of acrylic? I've been working around solvents for years, so smells don't really register for me.
Good Answers: 266
08/06/2010 1:38 PM
Modified Polyurethane
www.xtrabond.com
Good Answers: 58
08/06/2010 9:44 AM
I am not sure what the material is in your photos.
In addition to the comments above, another option may be;
Given the width of the joint, the only commercial grade caulk that I am aware of that will successfully seal a wide gap (up to 6" wide) is Permachink which is used on log homes to seal between the logs, around windows and doors to prevent migration of dirt, dust, water, ect. into the home. This product can be used inside or outside.
I have quite a bit of personal experience with this product and am satisfied with its performance.
You fill in the gap (below the finished surface level) with "backer rod" (closed cell foam strips sold by Permachink), apply "Permachink" caulk and tool the Permachink using a spray bottle of water and a spatula to get the surface appearance that you want.
The purpose of the backer rod is that you only want adhesion on the ends of the adjoining surfaces and not across the entire span. This allows the product to expand and contract without splitting or tearing away.
Here is a link: http://www.permachink.com/?gclid=CNimkof5pKMCFQfyDAod9i2f3Q
Once you apply the "Permachink" and allow it to cure, the manufacturer does recommend an application of a top coat (which the on-line store has available).
Visit the site and read the literature, it may fit your need. I have dealt with this company for years and am 100% satisfied.
Hope this helps – Good luck!
08/06/2010 11:36 AM
The first posters are all on the right track. KJK/USA hit the point about backer rod, which is the key to success on wider joints.
I have seen successful caulk joints 8" wide; these were not an attempt to cover an error, but a part of the designed building expansion system.
Other than that, caulk material selection depends on service. I have also used SIKAFLEX with satisfaction... expensive, but a good industrial sealant. Not really an endorsement of SIKA, but a satisfied customer comment.
08/07/2010 11:58 PM
The finish in your upper right photo is typical of caulking applied with some skill. If it had been post-tooled, it would be smoother. I'd agree with others that is appears to be a modified polyurethane.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Doorman (1); KJK/USA (1); kramarat (3); MoronicBumble (1); ozzb (3)
