Previous in Forum: AC Drive Tuning Advantage   Next in Forum: Starting a New Residential Construction Project
16 comments
Generator Rotor Disassembly
08/08/2010 7:27 PM
I was trying to change generator head but stuck at old rotor to engine disassembly. Any tricks or ideas. Maybe i m not doing it right.
Re: Generator Rotor Disassembly
08/08/2010 7:42 PM
Have you read the manual? Do you have the manual? Etc. etc.etc.
Maybe you just need a big HAMMER, who knows?
Just Google "old rotor to engine disassembly" if you don't know make, model, etc. etc.etc
Location: West Point, Texas population around 200.Located between Austin and Houston
08/08/2010 8:51 PM
What is the material of the shaft,,,and
what is the material of the pulley, ,can you heat it ,,as in oxcy/acyl
torch???
Different metals have dissimilar expansion ratios.
Work Safe
Joe in Texas
We hold these truths to be self evident,one nation under God
08/08/2010 8:58 PM
well its mouted right on the engine shaft ..no pulley,its a portable generator.Rotor is aluminium and plastic.
08/08/2010 10:42 PM
Is it a portable that is mounted on a taper, They usually say to loosen the through bolt and tap it on end, you may ruin the threads, I've sometimes sacrificed the ball bearing on end and hit it hard at right angle to the rotor or sometimes used a block of wood and a dead blow hammer on the laminations, but be careful, its sometimes is hard to separate the tapers.
Good Answers: 16
08/12/2010 7:30 PM
+1 on Norton.
In my youth I worked at Generac in Wisconsin. The factory method was to loosen the thru bolt and whack with a hammer. Barbaric but effective.
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
08/09/2010 11:03 PM
I replaced the slip rings on my friend's Onan 4 kW genset in his RV. The slip rings are located behind the flywheel. It is an aluminum flywheel attached to the rotor instead of the engine. It's designed to blow the cooling air through the generator then to the engine.
Long story short: There were three untapped holes in the flywheel. I drilled the holes for 5/16 Heli-Coil to make sure the threaded connections would be strong. I then had to use a gear puller on the flywheel. I had the gear puller torqued to the hilt and had to whack the puller with a good sized ball pein hammer for several minutes, tightening the puller as I went. The flywheel was on a tapered shaft and it popped off with a vengeance. Make sure you have a safe landing place for the flywheel because this one came off and landed about 18 inches away. Scared the _ _ _ _ out of me when it went. I thought it was a standard straight shaft.
08/09/2010 11:11 PM
the thing is rotor is made of plastic and aluminium.iIDK what to hit .tried to fit wrenches in side nd hit on them alternatively both sides no luck tho.flwheel i know its hard and thinner than rotor.
08/09/2010 11:14 PM
Any chance you could post a picture of it where it attaches to the engine? Then we might be able to better identify a suitable removal method.
Thanks
08/10/2010 7:52 AM
I'm with Brave Sir Robin on this one. I've disassembled many different types of generators, some of them were old generator/welder type; some the newer "disposable" engine/genset for the hobby/homeowner. There is usually a place to grab the flywheel or generator frame to separate it from the engine crank by means of a puller. Sometimes you have to use the frame bolts that hold the generator/rotor end to the frame as the pulling points.
Chris
Chris
08/10/2010 10:46 AM
Actually I didn't replace the slip rings, it was the brushes. (Late night, brain not good). I did have to polish the slip rings though because for some reason, one slip ring had a black non-conductive crud build-up on it that ate away the brush. That brush was a half-inch shorter than the other. Some 400 grit emory paper followed by a good polishing with some crocus cloth and fastidious cleaning with acetone should ensure longer life with the new brushes. The sucky thing was this genset only had 350 hours on it when it stopped working (started but shut down as soon as the start button was released, due to lack of AC power at the sense connections).
08/10/2010 12:12 AM
I would think Google would be your friend on this. if the engine is a name-brand, a search of model number would yield crankshaft info.
That would definitely shed a little light on the subject.
Sorry, bad pun!
I Agree with all posts re: taper shaft, most likely a copy of good old Briggs and Stratton tapershaft..... I assume this is a low-buck gen-set, is it really worth fixing?
Sometimes you need to sacrifice the component that is being replaced. - if the engine is toast, go at it from that direction. If the rotor is fried, zipwheels are a quick method of removal.
All this talk of toasted motors and fried rotors are making me think of breakfast...
Good Answers: 39
08/10/2010 2:17 PM
Mechanics call it a "picklefork" tool used to seperate ball joints in steering gear. I disassembled an old generator with this tool. It has a wedge shape on each fork tyne that pushes the shaft off the taper of the engine shaft. A couple of hits with a 2 lb hand sledge and the genshaft separated from motor shaft.
Elnav
08/10/2010 10:54 PM
08/11/2010 1:13 PM
Is the end of the rotor threaded, if it is you can try a slide Hammer
08/28/2010 8:42 PM
Thanks guys.whacking thing worked.i was scaring for nothing.
sorry for delay in reply .
Register to Reply 16 comments
Anonymous Poster (1); Brave Sir Robin (3); Cbrunner (1); Delmar (1); elnav (1); garth (1); gsearay19 (3); johnnybravo (1); Judge (1); lyn (1); norton850 (2)
