Previous in Forum: Artificial Salt Lake   Next in Forum: Highly Reflective and Easily Sourced Film for Solar Concentrator?
8 comments
Regarding Unsaturated Polyster Resin
08/16/2010 1:26 AM
I'm doing some casting work with unsaturated polyster resin. The shop from where I bought these chemical that shop owner told me to take 3% Cobalt as aceleator and 1.5 % hardner (i.e. MEKP). But while curing, it is getting cracks. I'd like to know exact percentage of hardner (i.e. MEKP) and cobalt (Acceleator) for 550 ml quantity of base resin. Could you please help me friends.
Pankaj
Re: Regarding Unsaturated Polyster Resin
08/16/2010 2:48 AM
Contact the manufacturer directly.
08/16/2010 3:39 AM
If it's cracking, you are using too much hardner and/or accelerator or making too big of a batch.
Reduce the concentration of both until satisfactory results are obtained.
Or, call the manufacturer.
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
08/16/2010 3:19 PM
Curing and applicalion temperature can have an effect too
Give me enough duct tape and I can fix anything!
08/16/2010 3:25 PM
And on and on. Polyester is especially difficult to trouble shoot long distance due to all the variables. It's not like a two part epoxy.
My advice is start out under-catalyzed and work your way up to adequate cure in small increments.
08/17/2010 2:37 AM
3% Cobalt isn't too high ... use a little less to to slow the volume expansion & subsequent shrink RATE (1.5-2%) ... and make sure you mix it really well. The MEKP is correct. Insulate the castings for 12 hours minimum ... to slow the shrink rate.
If you have an enclosed interior volume, you need to leave a hole in it somewhere ... or when it heats up, it will really expand ... then shrink as it cools ... and crack ... if I were to bet I think that is the real problem. It will shrink by about 2% already ... so if it expands with entrapped air, it will shrink by two different means and crack like crazy.
08/17/2010 8:59 AM
You need to cut down to 1.5 to 2 % of Cobalt and 1 to 1.25 MEKP in 550 ml quantity of base resin.
After casting cover it and let it shrink slowly overnight before opening the cover and you will be okay
Masyood
Canada - Member - New Member
Good Answers: 39
08/17/2010 11:24 AM
May I slip in a side question, I don't want to hijack a thread?
What is the difference between saturated and unsaturated polyester? They have different numbers in my import tariff and polyester is the only plastic that asks this question. Is there an easy way to tell them apart? (Something I can ask a non-chemist)
Again sorry for the interuption.
All that is required for evil to succeed is for good men to do nothing.
08/17/2010 12:52 PM
An unsaturated polyester is a polymer chain containing alternating dibasic acid and glycol monomers linked together by ester bonds. The unsaturation comes from the incorporation of a dibasic acid that contains a double bond, typically maleic acid formed by the ring opening of maleic anhydride. As the concentration of maleic acid in the polyester chain increases, so does the resin's reactivity. Several different glycols and/or dibasic acids can be copolymerized into the polymer chain. At the end of the reaction, the polyester resin is blended with a reactive diluent, typically styrene. The reactive diluent contains a vinyl double bond and serves to reduce the viscosity of the polyester resin so that it can be pumped and processed. Hence, the resin manufacturer can produce a wide variety of polyester resins with differing structures, reactivities, and molecular weights, which impart different properties to the resin and the final molded product.
Now,why are they classified differently? I don't know, and I can't even find the excellent site where I copied the information above. If I find it, I'll put it up here.
Back to the Original Topic.
This is from:
Register to Reply 8 comments
Anonymous Poster (1); Apothicus (1); farmatt (1); lyn (3); Masyood (1); one2playwitt (1)
