Previous in Forum: Callibration of CNG Tanks   Next in Forum: Effect of Inlet Cone of PA, ID, and FD Fans on Fan Performance
27 comments
Meaning of the Terms Bolt, Nut, Stud, and Thread
08/19/2010 5:06 AM
Dear friends,
In general "bolt" is used to fasten more than one components together with the help of a corresponding size of the part called "nut". The nut may be a loose part OR it may also be the machine BODY to which we assemble other part to the machine, then it is called a "stud". The studs have the "thread" (always external only) on BOTH sides. The torque place is provided in the mid-portion this stud.
Where as the "screw", with its "tapered" external thread portion, self sufficient to act like the TAP when applying the axial & rotational forces simultaneously.
If I'm wrong, please excuse me.
THANKS.
S.M.A
Re: skmoulaali
08/19/2010 5:19 AM
"Shocking news is coming in about a maniac that escaped from a mental hospital, ran into a high street launderette, raped several women and is still at large."
The headline read: Nut screws washers and bolts.
Good Answers: 58
Re: skmoulaali
08/19/2010 12:12 PM
Hysterical!!!!!!!!!
I will clean the coffee off of my key board and monitor now.
Re: skmoulaali
08/19/2010 1:00 PM
Correct web link about washers?
08/19/2010 4:18 PM
woodygb, the link posted takes me to a site that wants me to buy a domain name.
??? Twisted link?
Re: Correct web link about washers?
08/19/2010 4:30 PM
OK ...I'll try again
... A washer is essential.
08/19/2010 4:46 PM
May work for you - but not for us:
If you want everyone to see the pic, best way is to download it to your PC (right click ... "save image as" (or something similar)). When it's on your HD, use the "Insert/Edit Image" green camera icon , and browse for the copy on your HD to put it in your post.
Gotta do it now, 'coz you've got us all wonderin'
08/19/2010 5:13 PM
any better?
08/19/2010 5:19 PM
That's the one! (but don't show sue).
Re: skmoulaali
08/19/2010 6:21 AM
Please see this part of the Wikipedia entry for "Screw":
http://en.wikipedia.org/wiki/Screw#Differentiation_between_bolt_and_screw
The word "Screw" is very often used in engineering (and other) circles for what you describe as a bolt.
Re: skmoulaali
08/19/2010 8:25 AM
The differentiation in everyday use is very nebulous. In fact in common usage both are too often mixed up.
For all practical purposes hence as Wiki has pointed out in the link provided by you.
But the more accepted definition may be what is turned to tighten or loosen.
Bolt is when the head is held stationary with the item being fastened and the load is applied by rotating the nut.
Screw is when the nut (or threaded part) is held stationary and the fastener is rotated by turning it through its head
In quite a few cases then it makes the same fastener - become screw or bolt.
Re: skmoulaali
08/19/2010 7:05 AM
You're excused.
Only some screws are tapered. Many are not.
Good Answers: 266
Re: skmoulaali
08/19/2010 7:20 AM
Anybody use a nut on their dead bolt to hold the door fast?
Re: Meaning of the Terms Bolt, Nut, Stud, and Thread
08/19/2010 11:11 AM
As an apprentice back in the 70's , I was taught that a bolt had a section of plain unthreaded shank under the head , whilst a screw had thread all the way up to under the head.
http://www.boltscience.com/pages/glossary.htm
Regards Woody
Good Answers: 97
08/19/2010 5:31 PM
What would the devices attached to the Frankenstein monsters neck be called?
CRTL-Z
08/19/2010 6:01 PM
Ribbitsivets:
Good Answers: 22
08/19/2010 10:51 PM
Torso and Head?
08/20/2010 5:38 AM
Ears?
You're never too old to learn.
08/20/2010 12:29 AM
Welcome to CR4
Recent Title of a news in some newspaper (given by mechanical engineer turned to reporter):
"A nut screws washer (woman) and bolts"
08/20/2010 4:02 AM
Congratulations!
Strangest, funniest, most inappropriate, inaccurate, meaningless post EVER on CR4. Especially the bit where a Nut can be called a Stud which has a thread both sides. Anybody ever seen a square Stud?
And what in heaven's name does "The torque place is provided in the mid-portion this stud" mean?
08/20/2010 12:19 PM
I've seen studs with hexagonal sections in the middle.
Canada - Member - New Member
Good Answers: 39
08/20/2010 1:42 PM
This thead may be many of the things you suggest but it is not meaningless when you consider that almost every country distinguishes between screws and bolts in their import/export legislation. And most coutries will issue a fine if you get it wrong.
All that is required for evil to succeed is for good men to do nothing.
08/20/2010 9:59 PM
Lighten up a bit. His English isn't our English! And British English isn't the same as American English. (Nor from one end of the USA to the other!)
Threads on both sides obviously (to me) means both ends. Most studs that I have seen have different threads on each end; that is coarse on one end & fine on the other. Or maybe a tapered wood screw thread on one of the ends. With these there is usually a short unthreaded portion between the end threads. This would be the "torque place."
Lehman57
08/24/2010 4:41 AM
I'm light Lehman. It's just that there are people who think they can post any old drivel on here whether their first language is English or not. I have previously criticised contributors who post comments/answers that are erroneous and sometimes dangerous if their advice is adopted so I may be over-sensitive.
However, this guy is SO wrong on almost everything! Ok, I take your point about the "threads both sides" meaning both ends (apologies for not understanding), but what you and he describe is what I know as a Hanger Screw (or Hanger Bolt) not a Stud, so I can't agree with either of you on that one. (I think you might find that Wikipedia states something similar). However your explanation clarifies the OP's "torque place" phrase for me because some Hanger Screws have a hexagonal unthreaded portion to take a spanner/wrench, so this now makes sense to me.
Other than that, the OP's contribution to our "engineering workplace" is, in my humble opinion, less than NIL. Sorry again, but that's the way I see it. Call me old and grumpy if you wish.
08/20/2010 8:53 AM
Studs do not have to have threads on both sides. By both sides i am assuming you mean both sides of what it is going through (i.e. panel, plate, etc.). There are studs used to hold on automobile wheel rims. Those studs are pressed in and no need to have access to the opposite side.
J B
Good Answers: 97
08/20/2010 9:46 AM
Then there is the "socket head cap screw" which was developed to retain the hats of pugilists.
CRTL-Z
Good Answers: 39
08/20/2010 12:42 PM
Telling the difference between a screw and a bolt is easy.
Just read and memorize this 20 page ruling from US Customs.
http://www.cbp.gov/linkhandler/cgov/trade/legal/informed_compliance_pubs/icp013.ctt/icp013.pdf
There wasn't that simple? There is a much longer court case on this subject but i wasn't able to locate the transcript on the net. Now up here in the great white north the customs tariff further breaks screws down into, coach screws, wood screws, selftapping screws, cap screws, machine screws, drywall screws, sems, and other. Yet when I called the office that is in charge of this part of the tariff they admitted that nobody there knew the differences between the different types because it was written so long ago that the people involved are probably dead.
But we are still faced with the problem that a socket head cap screw from China is duty free but a socket head screw that is NOT a cap screw is subject to 180% antidumping duty. The typical answer a client gives to the question "is your screw a cap screw or not?" is usually "You're kidding right?"
The anti-dumping legislations is all clearly explained to us in a document with such paragraphs as: "There is a difference between wings screws and screws with wings, the former are excluded while the latter are, with the exception of machine screws with wings, included."
Welcome to my world and I hope that cleared up this question for you all.
08/20/2010 3:38 PM
Hence the term NUTS or SCREWY!!
Register to Reply 27 comments
Anonymous Poster (2); Apothicus (2); Doorman (1); gsuhas (1); JBTardis (1); Jeanne P. (1); JohnDG (4); KJK/USA (1); Lehman57 (1); M Daniels (3); OldTechNewToys (1); ozzb (1); PWSlack (1); Unredundant (2); woodygb (5)
You might be interested in: Thread Gages, Thread Rolling Machines, Nut Runners
