Previous in Forum: How an Alternate Signal Travels in a Wire..??   Next in Forum: Calculate 12v Battery Expectancy
9 comments
Good Answers: 97
Rat-Race
08/29/2010 3:35 AM
We are currently using PMR 446 two way radios (similar to the American Family radios ) for our neighbourhood watch.
A while back I wanted to use two sets on one areal but blew the receiver on the second set when transmitting directly into the port.
A Rat-Race (thanks to Mr Wiki) would have solved my problem.
Set 1 at A
Set 2 at C
Areal at B
The length of the path from A to C is 1/2 wave length on the one path and 1 length in the other direction. Resulting in zero power at the input of C .
Quite clever?
We are now moving over to a licensed frequency and must for a while use both systems.
Can the circuit be adapted to protect the receivers when 446 and say 480 MHz sets are used?
Good Answers: 60
Re: Rat-Race
08/29/2010 8:57 AM
No
the frequency of each radio is different so a different length would be needed
and if it did work the transmitting radio would desensitise the receiving radios
http://www.google.co.uk/search?q=operating+multiple+radios+from+one+ariel&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=_ld6TO3lOc7p4gbevvDYBg
you may get away with a discone anttena this is an ariel that works on multiple frequencise able to recive and transmit
if it was me i would try a 1/4 wavelenth of each frequency coax cable feeding a T piece then onto the ariel make sure the feed from the T piece is not a multiple of either frequency
http://www.google.co.uk/search?q=discone+antenna+design&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=clh6TIWwA5iL4gbu97XHBg
http://www.google.co.uk/search?q=american+amatuer+radio&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=r1p6TPG3Mcv24gborry2Bg
sorry
Good Answers: 204
Re: Rat-Race
08/30/2010 12:32 AM
Both you are radio users... and I commend that.. but I must say the word you are looking for is "Aerial"
not areal etc. shame shame...
Good Answers: 60
Re: Rat-Race
08/30/2010 4:19 AM
i have always been rubbish at spelling.
i can take your car apart in a field and reassemble it with improvements but spelling noo why.
oh and my mental arithmatic is even worse i am lost without a calcuta (calculator)
Good Answers: 204
Re: Rat-Race
08/30/2010 1:55 PM
love the new avatar too!
Good Answers: 60
Re: Rat-Race
08/30/2010 2:51 PM
Thanks i got it from a poster her on CR4
and heres some more
Re: Rat-Race
08/30/2010 10:56 AM
Any such device is going to have insertion loss, something you may not find acceptable. Too, it should be subjected to lab testing, with applicable test equipment, to verify adequate isolation, else you may be back with the same problem (damaging another receiver).
The "rat race" device, or similar, does not exhibit the "Q"/selectivity needed and thus would not offer enough isolation in my opinion and certainly severe receiver desensitation would be realized.
Reconsider using two antenna systems with vertical separation.
Good Answers: 60
Re: Rat-Race
08/30/2010 4:08 PM
Good Answers: 60
Re: Rat-Race
08/30/2010 4:12 PM
Register to Reply 9 comments
Bill ML (1); chrisg288 (2); peterg7lyq (6)
You might be interested in: Radios, Die Sets
