I am building a cart to haul my canoe or kayak behind my Quad so I can access back country lakes. I opted for ABS as the construction material to use. Like bamboo it flexes over rough terrain but is extremely strong. The difficulty I am finding is in the joints where the "T"s and "Y"s meet the pipe.. Any failures come at these joints. Does any manufacturer have a longer sleeve entering the joint for longer contact between fitting and pipe and as a result better weight bearing. I think if a small manufacturer with a little foresight could do this and add maybe a dozen specialized fittings that had a longer entry sleeve this material could be used like a large scale Meccano set to build anything. The question is does such a thing exist and if not I present it as a challenge that could prove lucrative for any existing or new manufacturer of ABS. Are there any other suggestions out there that could improve the integrity of these joints.
