Previous in Forum: Generator   Next in Forum: How to Work Out Cable Cross Sectional Area?
Capacity of Diesel Generator Day Tank?
08/30/2010 11:05 PM
Dear All,
We have two(2) big Diesel Oil storage tanks and the diesel oil day tank for each emergency diesel generator.
The day tank is installed beside each generator on the ground level and oil is fed to day tank by supply pumps from storage tank.
I'd like to know how to decide the capacity of diesel oil day tank for each generator.
Is there any regulation for the sizing of day tank from international Code and standard?
Please Let me know.
Good Answers: 181
Re: Capacity of Diesel Generator Day Tank?
08/31/2010 2:08 AM
There must be an echo around here.
You asked same question a couple of days ago!
08/31/2010 3:05 AM
Was it the same guest, though?
Good Answers: 181
08/31/2010 3:09 AM
Must have cut and pasted the question.
09/06/2010 3:23 PM
Dear Guest,
In the absense of further details, you need to decide how long your generators may run unattended, before someone refills them with fuel. Assuming, by describing the tanks as "Day Tanks", you want them to last 24hours. The generator engine manual wil give you the fuel consumption per hour at maximum load. From this figure, work out your fuel consumption at maximum load for 24 hours, then add a factor of safety of, say 10%. Your day tank size needs to be at least 20% bigger than this figure! Why, because you do not want to fill your day tank above 90% capacity, in case it overflows when you fill it, and you do not want the tank level to drop below 10%, in case your delivery pipe at the bottom of the tank is exposed, causing fuel starvation, or you suck up any water or dirt that is in the bottom of the tank, blocking your filters. This is the rough rule of thumb I would use - I can't answer whether there are any International Codes or standards for the sizing for land based installations, but for day fuel tanks on ships, LRS Rules state for ships over 500GT there has to be 2 service tanks for each type of fuel used, of sufficient capacity to allow 8 hours running of the main engine(s) and generators for 8 hours at MCR.
halibutA (1); PWSlack (1); TonyS (2)
