I did a brief search in CR4 on CFLs and did not see anything pertaining to my most recent issue with CFLs.
Have any of you had a problem using CFLs in a ceiling fan. I tried using CFLs in my fans that I leave on pretty much 24 hours a day. The fan is left on 24 hours a day not the light. But the other day my wife started screaming about smelling smoke in her craft room. It took a while but I eventually found the problem. The CFLs I had in the fan were all scorched at the joint where the bulb met the light base.There were two brands of lights in the fan, Phillips and what I believe is the Walmart brand. Both had the same scorch marks. I am assuming the normal vibration from the fan cased the failure.
And what about appliance lighting. If they phase out incandescent lights what will we use in things like Ovens and Refrigerators. I've had no luck with CFLs in outdoor light during the winter either.
I sticking with incandescent lights and LEDs from now on.If LEDs weren't still so expensive I'd be switching to them. But even they have their limits.
