Previous in Forum: What Oil Can be Used to Blacken Parts from Temper?   Next in Forum: RFID Handheld Reader for FOD
24 comments
Sphere Bursting Pressure?
09/02/2010 10:14 AM
I hate Math!
Can anyone help me here. I want to know what the internal Pressure in PSI ( Pounds Per Square Inch ) is of a sphere with the following specifications.
Diameter of Sphere, = 13 meters
Tensile Strength of the material that is the skin of the sphere, = 16.6 Mpa
What will the the internal pressure of this sphere (Think of it being like a balloon ) What PSI would be inside, when this skin would fail.
Thanks Everyone
Re: Sphere Bursting Pressure?
09/02/2010 12:24 PM
One of the key variables is missing here: the thickness of the material.
09/02/2010 4:37 PM
very thin, less than 1 mil thick at the most, and more like 1/4 mil
Thanks
Good Answers: 74
09/02/2010 5:57 PM
t = 1 mil = 1/1000 of an inch. Is that what you mean?
1/1000" = 0.0254 mm
Assuming D is 13m after pressurizing
Py = 4 * 0.0254 * 16.6/13000 = 0.00013MPa or 0.13kPa or 0.019psi
If t is 1/4 mil, Py is 0.52kPa or 0.075psi
I don't think it would be possible to handle such a material without breaking it, so the answer has no meaning.
Bruce
09/02/2010 7:22 PM
The Material is a latex high altitude weather balloon.
Good Answers: 74
09/02/2010 8:46 PM
When is the diameter equal to 13 metres? If it is at the time it bursts, then my previous answer is correct. Otherwise, it is not.
Bruce
09/02/2010 9:03 PM
yup thats the rated bursting diameter 13 meters.
09/02/2010 9:06 PM
care to run the numbers again, everything is the same, but with a diameter of 9.44 meters this time?
Joe
Good Answers: 74
09/02/2010 9:25 PM
Actually, I don't care to "run the numbers again with D = 9.44m". I have given you the method of calculating it. So do it! And if you can't do it, find someone who can. If you have such a deep hatred of mathematics, perhaps you should not be involved in mathematical problems. Maybe you should try your hand at poetry...for example:
"There was a young man from Peru
who dream't he was eating his shoe
He woke in the night in a terrible fright
And found it was perfectly true."
OR:
There was a young man from Bengal
Who went to a fancy dress ball
He went there for fun, dressed up as a bun
But a dog ate him up in the hall.
Your turn.
Bruce
09/02/2010 9:58 PM
I'll try.
I'm just not sure where the 13000 came from for one thing, and when something is 4 times thinner it ends up being 4 times stronger? that lost me
sorry,
Joe
Good Answers: 74
09/02/2010 10:13 PM
The diameter of the sphere was 13 metres. That is equivalent to 13,000 mm. I used mm in order to keep the units consistent. When something is 4 times thinner, the stress is 4 times larger. That means the strength is 4 times smaller.
Bruce
09/02/2010 10:22 PM
Thanks for this assistance, but see what I mean your original says
why is the pressure rating 4 times higher in pressure see? in other words when it says 0.075 Psi,
that means then that at that pressure the balloon would pop correct?
Joe
Good Answers: 74
09/02/2010 11:34 PM
Sorry, I was in error! Call it a senior moment. I should have said "If it is 1/4 mil, Py is 0.0325kPa or 0.0047 psi".
Bruce
Good Answers: 74
09/02/2010 1:30 PM
Total force on shell = P*A = P*πD2/4
Length of shell resisting force = π*D
Force per unit length of shell = P*D/4
Failure strength per unit length = t*Fy
Pressure at yield, Py = 4*t*Fy/D
t = thickness of shell
Fy = yield strength
D = diameter
Bruce
09/02/2010 11:10 PM
Ummm, are you sure that is right !
I do not have my theory book in front of me to check for recognised formula, but since a sphere has three dimensions, the force on an element of the wall will be in two directions, the "x" and "y" - so won't it be necessary to add the two (Mohr's stress circle etc.) to get an accurate result ? It's not clear to me at a glance with your formulae that this was provided for.
In the more conventional cylindrical pressure vessel, the spherical ends are not a problem as the hoop stress in the cylinder part of the vessel is twice that of the hoop stress in the hemispherical end - but this is not the case here as the vessel is all sphere.
Good Answers: 74
09/02/2010 11:51 PM
I don't have a theory book in front of me either. If a sphere has an internal pressure P, then every section through the centroid has a force of P*A where A is the area of the circle, namely πD2/4. Mohr's stress circle does not enter into the discussion.
Regardless of which section we take, the perimeter resisting that force is πD, so the unit load must be P*πD2/4 divided by πD which yields PD/4. What is your problem?
Yes, I am sure that is right.
Bruce
09/03/2010 1:32 AM
My query boils down to the question of whether an element subject to a stress in one direction, will fail earlier if a stress is applied in two directions. Its about thirty years since I did that stuff, but I am thinking that the answer is, "yes it does", in which case your answer appears to be wrong. How confident are you?
09/03/2010 1:36 AM
Further comment to "self". On second thoughts you are probably correct -my concern would apply if the second stress was of opposite sign to the other. Like I said it is "thirty years"......
09/03/2010 10:07 AM
Everyone, I found this formula a while ago but still had no idea as to how to run it.
so with the information from the initial posting, does this work?
I hate Math!
Diameter of Sphere, = 13 meters, and how about a 9.44 meter sphere also?
What will the the internal pressure of this sphere (Think of it being like a balloon, well it IS a balloon. ) What PSI would be inside, when this skin would fail.
Thanks Everyone
Good Answers: 58
09/03/2010 11:26 AM
Your solution ignores the thickness and strength of the balloon material. A correct formula was provided in #20. Just make sure all your units are compatible.
Good Answers: 74
09/03/2010 11:46 AM
T = PR/2 is the same as T = PD/4 which I gave you in Post #2. It is the tension per unit length at all points on the surface of the sphere.
Pressure at failure is 4*t*Fy/D which is the same as 2*t*Fy/R, both of which were given to you earlier in this thread.
It should be obvious, even to one who hates math, that the failure pressure for a 9.44m diameter sphere will be 1.38 times higher than that of a 13m sphere. You need the thickness in order to find a precise answer.
Bruce
Good Answers: 58
09/06/2010 8:33 PM
FYI, the formula (T=ΔPR/2) is for the surface tension on the outside of a droplet. It doesn't apply to the problem you described.
09/02/2010 1:46 PM
<sigh> Carry out a force balance on a theoretical plane sliced through the centre of the sphere.....
09/02/2010 2:58 PM
I notice you've been sighing a lot lately. A vacation, perhaps?
Good Answers: 58
09/03/2010 9:07 AM
From Roark (5th ed), the pressure at failure = [2t ( strength )/Radius] where t is the thickness of the skin. Keeping units compatible, I come up with .0047 psi for the 13 meter diameter sphere at 1/4 mil thickness. This is theory. In practice, many factors such as temperature, time, or even a pin could alter your results.
Register to Reply 24 comments
ba/ael (8); Mikerho (1); NSS (7); PWSlack (1); Tornado (1); TrevorM (3); welderman (3)
