Previous in Forum: What is the Lowest Temperature Recorded?   Next in Forum: Pipe Size Calculation?
Chemical Dozing Design in HVAC
09/06/2010 7:40 AM
How to calculate capacity for a chemical dozing tank used in the chilled water system.? (say 60liters).
Re: CHEMICAL DOZING DESIGN IN HVAC
09/06/2010 8:38 AM
First find out the following:
  • What is the strength of the dosing chemical?
  • What is the required dosing rate of the chemical?
  • What is the daily or weekly consumption?
  • What is the minimum delivery required?
  • What is the interval between deliveries?
The rest is just arithmetic.
09/07/2010 1:52 AM
If we know all these things.How to calculate the capacity? for example 60liters capacity tank.how to come to a decision about the capacity?
09/15/2010 1:04 AM
among this which question may have the answer 60litres tank capacity.
Re: Chemical Dozing Design in HVAC
09/06/2010 1:18 PM
Will the chemical come in a drum/barrel …..all you need is to install the pump on top of the barrel and set the speed / stroke ….. and activate it with a timer. How often it is tested ? -Who is recommending the chemical and supplying it …... What do they say.
klearzen
09/07/2010 1:55 AM
How to come to a decision about capacity? say 60liters tank.?
abin.thomas (3); klearzen (1); PWSlack (1)
You might be interested in: HVAC Services, HVAC Controllers, HVAC Ductwork
