Previous in Forum: Chemical Dozing Design in HVAC   Next in Forum: System Volume in HVAC
9 comments
Pipe Size Calculation?
09/06/2010 7:46 AM
How to calculate pipe diameter required, if we know the flow rate ?
we can derive a formula from burnulis equation for pipe diameter.
ie; square root of ( 4*flow rate)/3.14*velocity).
can we assume velocity as 1.3m/s?
Re: PIPE SIZE CALCULATION?
09/06/2010 8:35 AM
It's got stuff-all to do with Bernoulli's Equation.
Just keep the velocity in a liquid pipeline between 1 and 3m/s. If the flowrate is known, out drops the diameter.
"Simples!ξ"
Good Answers: 137
09/06/2010 2:16 PM
That's rght, and his formula isn't Bernoulli's Equation anyway.
Cheers..........Codey
09/06/2010 5:25 PM
then what is it? spread the knowledge ,
Good Answers: 38
09/06/2010 6:46 PM
Where are you located guest ?....Spread the knowledge..!!
Good Answers: 137
09/07/2010 5:17 AM
It's just the formula for velocity = volume flow rate/pipe cross-section area.
09/07/2010 2:08 AM
So about 1.5m/s appro. thank you.
09/07/2010 2:09 AM
Is there any other easy formulas?
09/07/2010 9:33 AM
Eh? No other formula is needed.
Good Answers: 19
Re: Pipe Size Calculation?
09/26/2010 10:12 AM
take pipe diameter in mm squared x velocity in meters/s x .0028 = m3/hr
say a 25 mm pipe , velocity 3 m/s = 625 x 3 x .0028 = 5.25 m3/hr
Register to Reply 9 comments
abin.thomas (2); Anonymous Poster (1); Codemaster (2); ducon (1); MJCronin (1); PWSlack (2)
