Previous in Forum: Help, My Mattress!   Next in Forum: Labeling Solutions
Insulation Metal Jacketing
09/09/2010 11:58 PM
What is the optimum thickness of aluminum sheet (stucco embossed)required for jacketing of a conical roof tank (51 mtr dia).?? Tank roof jacketing has withstand frequent wind load and occasional rainfall. Also, what is the best way for securement of sheets and the sealants for waterproofing???
Rajesh Nair
Re: Insulation metal jacketing
09/10/2010 4:30 AM
  • What's in the tank?
  • What's its temperature and pressure?
  • What is the tank roof made of?
  • What is the insulation material?
  • What does the tank manufacturer recommend?
  • Why is jacketing the tank an afterthought?
  • Etc.
09/10/2010 5:03 AM
It's a Crude oil tank, Max working temp of 110 deg cent, Material of construction is carbon steel, Insulation material is LRB Rockwool 38mm thick. Tank manufacturer recommends 0.5 mm thk aluminum sheet for jacketing secured with self tapping SS screws at 150 mm pitch.
Regards,
Rajesh Nair
Rajesh Nair
09/10/2010 5:15 AM
Follow the manufacturer's recommendations, then.
09/10/2010 4:59 AM
  • Who put the insulation on?
  • What is the thickness of the insulation?
  • Why did this operation not put the jacketing on as well?
  • What do local Planning laws say about the appearance of the tank?
  • What restrictions on finish colour are there?
  • Etc.
Register to Reply 4 comments
You might be interested in: Roof Curbs, Roof and Floor Trusses
