Previous in Forum: Flange Adapters   Next in Forum: Hardness Tester
8 comments
Balancing Weights
03/09/2007 4:33 AM
hi, i require some advice on the best mechanism to use.
here is the system:
there are two bodies, body A and body B, body A is connected to body B via a joint. Body A needs to remain in a vertical position while body B rotates through a small angle.
I was thinking of using some sort of bearing and letting gravity do the work, or maybe some sort of counterweight.
Your advice would be appreciated.
d.b
Good Answers: 54
Re: Balancing Weights
03/09/2007 6:45 AM
It's a little difficult to imagine what you've just described. Could you provide an illustration?
03/09/2007 11:24 AM
I have no idea what your talking about. Counter weight to do what exactly?
03/09/2007 12:56 PM
My advice is that you should post a picture and tell us what it's worth. I was also not able to reach your level of abstraction.
Humm... suspicious you are...
03/10/2007 12:00 AM
Is body A connected to B by fixed or flexible joint? Can you please draw a skitch for that system?
03/10/2007 12:05 AM
03/10/2007 10:29 AM
Ask my mother inlaw she knows every damn thing. You might consider taking statics and dynamics yourself.
03/10/2007 6:22 PM
A sketch, please!!!!!!
Gabriel, Buenos Aires, Argentina
03/12/2007 10:02 AM
Dear Guest,
You have provided very little information.
A sketch is not entirely necessary, but a better description of the problem is...
I'm guessing you a first year mech design student ?
Regards
Guest 2
Register to Reply 8 comments
Abdel Halim Galala (1); Anonymous Poster (3); bhrescobar (1); Gabriel (1); Labyguy (1); Vulcan (1)
