Previous in Forum: Balancing Weights   Next in Forum: Self-heating on an RTD
14 comments
Hardness Tester
03/09/2007 9:19 AM
Our company is looking to purchase a portable hardness tester for use around the plant. We will just be using it to verify that our suppliers are supplying us with the hardness they say they are (we have had issues with this in the past). We are not looking for an extremely precise tester, just one that will give us a good idea that the hardness is close to the values quoted. In my quick research I have seen units ranging in the $1000 to $2500 range. Is this what I should expect to pay for a tester that will meet our needs? Also can anyone recommend any specific companies that make and sell a tester that would work well but not be overkill for our situation?
Re: Hardness Tester
03/09/2007 10:37 AM
Buy yourself an Equitip hardness tester. It is a hand held device and is about the same size, wheight and dimension as a ball point pen. Just type the name of the instrument in to google and you will get all your answers
Re: Hardness Tester
03/10/2007 8:16 AM
Hardness of what ? If it's concrete or something like that , rock engineers use what I think is called a schmidt hammer.
Re: Hardness Tester
03/10/2007 10:38 AM
What is the material you are trying to test?
Re: Hardness Tester
03/10/2007 1:32 PM
You remind me of someone asking:
"How much will it cost us drive the car?".
You want a serious answer, make a serious question.
Wangito.
Never trade luck for skill.
Re: Hardness Tester
03/10/2007 8:02 PM
go to online store for webster.its supply by qualitest.com from toronto canada cost is 1600 cad go to yahoo .com punch webster in search bar .u will be on tack otherwise send me ur emai at p12ca@yahoo.co
Good Answers: 97
Re: Hardness Tester
03/12/2007 4:26 AM
My first impression was for an instrument testing the hardness of water. This can be tested "scientifically" using a bar of soap. When i was young the "hard water" seems pretty soft to me - and i presumed hard water = ice.
After reading further
use a hammer.
if it splash it is very soft
if it makes "thud" it is soft
if it shatters it is hard but brittle.
if it cracks it is almost hard.
if it last it is hard.
etc.
Re: Hardness Tester
03/12/2007 7:48 AM
What a bunch of ignorant replies!
"We are not looking for an extremely precise tester" That means your probably looking for a durometer. The prices you mentioned sound about right. The pen versions may cost a bit less with a sacrifice of accuracy. Also, you'll need to calibrate them yearly, sooner if you use them daily.
Give Instron a call, they should be able to tell you exactly what you need to know. www.instron.com
Re: Hardness Tester
03/12/2007 8:29 AM
That might be good for your hardhat or skateboard , but the original question wasn't very specific about the intended use.
Re: Hardness Tester
03/12/2007 8:41 AM
Which hardness do you test?HRC,SHORE or others?
For above $1000 hardness tester,i think its HRS.For Shore hardness,it maybe be just about $100.
william.bei
Re: Hardness Tester
03/12/2007 8:54 AM
To first post, you havnt pointed out what hardness you will test? if its metal or nonmetal? if you want to test hb,hrb,hrc,hv,hsd etc, I recommend HL1 type hardness it drop down to your price range and can exchange these defferent hardness values.portable with micro printer. its testing range: hl300-900,hb80-650,hrb17.5-101,hrc20-68,hv-1200 friendly operation and digital display. if you are interesting in it pls write to info@ndt.cn if you want to know the hardness of concrete. you can select rebounder, its called schmidt harmer as well. it has pointer type and digital display. which one do you prefer?
Re: Hardness Tester
03/12/2007 1:22 PM
We are testing metal. I have very limited experience in this area but we are testing in the range of hrc20-70.
Re: Hardness Tester
03/12/2007 9:17 PM
yes. I think the hl can do it best and resionable price for your selection.
how shall I contact you?
Re: Hardness Tester
03/13/2007 4:47 AM
Three cheers for you . Some minor communication difficulty are resolved and a practical solution offered for the person who asked the question . If only all threads could end this way.
Re: Hardness Tester
05/21/2010 3:42 AM
it is the right time to let me know your needs , i worked for a manufacturer of portable hardness tester , i can supply you a EPX300 or EPX5500 portable hardness tester with good discount price, you can contact me lunahxl@hotmail.com
Anonymous Poster (5); cnpower (2); Hendrik (1); Kris (3); Pretendgineer (1); user-deleted-1114 (1); wangito (1)
