Previous in Forum: Measuring instantaneous power on bicycles   Next in Forum: Balancing Weights
Flange Adapters
03/09/2007 1:26 AM
Can anyone explain what is flange edapters?
Please tell me the site for reference.
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
Re: Flange Adapters
03/09/2007 1:40 AM
Well... A flange is simply a projection from a structure.
So a flange adaptor would be a structure that adapts something to a flange... ie- test apparatus, mating part, etc...
First Ref Page
Second Reference Page
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
Good Answers: 97
Re: Flange Adapters
03/09/2007 7:38 AM
Lots of applications.
In pipework a flanged adaptor could be to connect a rubber hose to a flanged steel pipe. The barrel is pressed into the hose (and clamped) and the flange is bolted on to the flange on the pipe.
a flanged stub shaft can be bolted onto the flywheel of an industrial engine.
etc
Re: Flange Adapters
03/12/2007 6:43 AM
It could also describe something to interconnect between different types of flange. Flange bolting varies according to pipe code: a 4in ASA150 flange will not connect directly to a 4in PN16 to BS4504, for example, as the pitch-circle-diameter, number and diameter of the bolts is different. If one wanted to join them, a short piece of pipe with one of each of the above on each end would enable the pipes to be connected.
fattmaxx (1); Hendrik (1); PWSlack (1)
