Previous in Forum: Datalogger for Recording Temperature & Humidity   Next in Forum: Conduit Fitting Selection
Flow Rate - Bend in Pipe Compared to Diameter
09/14/2010 1:30 AM
What is the minimum discharge the flow meter is to be installed form any bend in the pipe as compared to the pipe diameter? I can't remember the factor
Re: Flow rate
09/14/2010 2:15 AM
elaborate !r u talking about the min distance.
“Reality leaves a lot to the imagination.”
Re: Flow rate
09/14/2010 2:46 AM
It depends upon the flowmeter.
  • For a coriolis-based mass flowmeter there is no criterion, for example.
Refer to the manufacturer's information on the instrument; it will be there.
Re: Flow rate
09/14/2010 3:27 AM
Thank you. but i want the fomular
Re: Flow rate
09/15/2010 5:14 AM
The forum wants the type of flowmeter!
Good Answers: 29
Re: Flow Rate - Bend in Pipe Compared to Diameter
09/14/2010 1:26 PM
1. As PW says, it depends on the meter.
2. Here's some numbers for you to crunch since you insist.
09/14/2010 9:27 PM
Register to Reply 6 comments
mulenmar (1); omsumitam (1); PWSlack (2); RDGRNR (1); Tornado (1)
