Previous in Forum: Delta Motor Taking More Current   Next in Forum: Necessary to Connect Fuse at Negative Terminal of a DC Voltage System?
Difference Between XLPE and Paper Cable?
09/23/2010 12:28 AM
Difference between xlpe and paper cable?
Good Answers: 181
Re: cables
09/23/2010 1:30 AM
There're made of different stuff!
What do you want to know?
Re: cables
09/24/2010 12:00 AM
why xlpe cables have replaced paper cables in recent times
Re: cables
02/20/2024 7:05 AM
Wrong place to ask. The correct place is the ears of the people doing the replacing.
Re: Difference Between XLPE and Paper Cable?
09/23/2010 4:00 PM
xlpe= cross linked polyethylene
Paper=paper
Good Answers: 181
09/24/2010 1:39 AM
Paper
Dry paper is an excellent insulator but loses its insulating properties if it becomes wet. Dry paper is hygroscopic, that is, it absorbs moisture from the air. It must be sealed to ensure that there is no contact with the air. Because of this, paper insulated cables are sheathed with impervious materials, lead being the most common. PILC (paper insulated lead covered) is traditionally used for heavy power work. The paper insulation is impregnated with oil or non-draining compound to improve its long-term performance. Cables of this kind need special jointing methods to ensure that the insulation remains sealed. This difficulty, as well as the weight of the cable, has led to the widespread use of p.v.c. and XLPE (thermosetting) insulated cables in place of paper insulated types
Thermosetting (XLPE)
Cross-linked polyethylene (XLPE) is a thermosetting compound which has better electrical properties than p.v.c. and is therefore used for medium- and high-voltage applications. It has more resistance to deformation at higher temperatures than p.v.c., which it is gradually replacing. It is also replacing PILC in some applications. Thermosetting insulation may be used safely with conductor temperatures up to 90°C thus increasing the useful current rating, especially when ambient temperature is high. A LSF (low smoke and fume) type of thermosetting cable is available
11/23/2010 4:37 AM
very good explain.
Register to Reply 6 comments
Anonymous Poster (1); lyn (1); PWSlack (1); TonyS (2); tusar (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
