Previous in Forum: Use of Variable Frequency Drive in Energy Meters?   Next in Forum: Wound Rotor Motor
9 comments
Min Cable Insulation Value
09/25/2010 10:25 AM
I have to check the insulation for cable for 210kW (415V) motor, 3C x 185 sq.mm.
What is the minimum acceptable cable insulation after megger test with 1000V?
Good Answers: 181
Re: Min Cable Insulation Value
09/25/2010 10:54 AM
Have a look in Google or search this forum!
09/25/2010 11:23 AM
What does the specification say? You DO have a specification, right? Why else would you know that you are supposed to test? And if you know that you are supposed to test, you should know why and what the requirements are, right?
09/25/2010 12:46 PM
The OP wants to fail the cable. By failing this cable, he'll prove to his boss that he's a knowledgeable employee doing his job. The problem is he doesn't have a specification or requirement to show off his capabilities. That's why he came to us.
Well I'll give some numbers to suit the goal.
The minimum insulation resistance at 1000V is nothing less than 1012 ohms for a one meter length of cable. Now if you wish to really show off, you can also measure the cable's capacitance per meter which should not be more that 10-12 farads.
09/25/2010 5:30 PM
09/26/2010 6:31 PM
1000 ohms per volt--general rule .
09/27/2010 12:55 AM
If that were the case, then no residual current device would ever do anything other than trip! So the answer is inctredible.
09/27/2010 3:06 AM
Identify what type of cable your testing (should be marking on outside sheath) and, search for cable spec. or speak to the manufacturer.
09/27/2010 9:05 AM
Thumb rule which is applied in field for Insulation Resistance ( IR ) testing of cable is :
Rated Voltage of cable ( in KV )* 10/ Length of cable ( in KM ) in Meg. Ohms.
Manindra
09/29/2010 1:30 AM
As a thumb rule for for 415V motors, minimum acceptable cable insulation should be 1 Megaohm. There is a formula:
Safe Minimum IR value = Rated Voltage/ (Rated output in KVA) +100.
In your case it comes as 1.14 Mohms.
BB Raina
Register to Reply 9 comments
Anonymous Poster (2); BB Raina (1); lyn (1); manindra (1); PWSlack (1); redfred (1); TonyS (1); Tornado (1)
