I'm looking for a metal to use as an injector needle valve/nozzle and am having some difficulty wading through the tech. specs. and not finding any reference to it's resistance to ware at different temps. and its stability in fluctuating temps. I've been looking mostly at high temp nickel eg. inconel x 750 ... and I would like to know how a metals modulus of elasticity effects a needle valve under pressure typical injection pressures of 20000to 30000 psi. are not uncommon in a diesel engine .this valve will protrude into the combustion chamber and see all its extremes
