Hi folks.
I want to calculate the rpm of a windmilling boat propeller on basis of the boat speed and any propeller data(number of blades, Pitch ratio, disc area ratio and blade section type etc.).
I have looked in several books concerning propeller choice and design, and leaned about the use of standard series data design(waganingen b-series and the Bp-delta diagrams), but known power and rpm seems to be a requirement to use this method.
I have also studied reports on sailboat propeller drag, and the use of the kq & kt curves in the negative regime of propeller performance curves, but once again a known n(rpm) is needed(to calculate other parameters used to enter the diagrams).
Theoretically the rpm should be equal to ships speed/pitch(v/p), as pitch indicate the distance a given propeller would "drive" forward for each full rotation. But then the resistance of the hub along with the water resistance and drag in general, wouldn't have been taken into consideration.
I guess this problem could be solved by the use of fluid dynamics, but i don't know anything about CFD, and would rather use some empirical method, if there is on.
The influence of wake and isn't important at first.
Hope to get some inputs:)
