Previous in Forum: Overspeeding an Asynchrone Electric Engine   Next in Forum: Bus Duct Design
Pilot Bus and Slack Bus
10/05/2010 5:09 AM
Are the pilot bus and slack bus the same or there is a difference?
Re: Bus.
10/05/2010 6:48 AM
What a personal question!
Re: Bus.
10/05/2010 7:26 AM
So this must be the slack bus.
Nice ride!
Good Answers: 244
Re: Pilot Bus and Slack Bus
10/05/2010 7:39 PM
In the power system, the pilot bus and slack bus are not the same.
Slack bus is the reference bus for the load flow calculation in power system. It is also known as swing bus or reference bus. Generally it is the bus to which the largest generator of the system is connected and its governor is set to isochronous mode (see http://cr4.globalspec.com/thread/42805 for isochronous mode) for load control.
The Pilot bus refers to the set of Voltage Controlled buses (or Generator bus or PV bus) used for the zonal system voltage control for the Secondary Voltage Regulation (SVR) system. Sometimes, it is also called weak bus or critical bus.
For more detail, see these links:
http://cr4.globalspec.com/thread/53251/Power-System
http://thunderbox.uwaterloo.ca/~ccanizar/papers/BoIREP.pdf
http://wvuscholar.wvu.edu:8881//exlibris/dtl/d3_1/apache_media/21241.pdf
- MS
Mikerho (1); msamad (1); PWSlack (1)
