Previous in Forum: Acrylic Hull for Underwater Vessel   Next in Forum: Finding the SINTAP Standard
Latent Heat of Water
03/13/2007 6:07 AM
Dear All
I require the Latent heat of water, the amount of heat that water consumes without a change in its temperature.
Pathfinder Tags: Latent heat of water
Re: Latent heat of water
03/13/2007 6:19 AM
More accurately:
"The specific latent heat of fusion of a substance is the amount of heat required to convert unit mass of the solid into the liquid without a change in temperature."
and
"The specific latent heat of vaporization is the amount of heat required to convert unit mass of a liquid into the vapour without a change in temperature."
I don't know which one you are looking for since you didn't specify, but I'm sure that you can find both values for water through an internet search.
Regards,
Mike
03/13/2007 7:55 AM
For fusion =334 Kj/Kg
For evaporation =2258 Kj/Kg
That took me less than a minute on google ! Anyway hope it helps , Kris
03/13/2007 8:50 AM
Latent heat of evaporation varies with saturation temperature/pressure, from 2501kJ/kg @ 0degC, through 2257kJ/kg @ 100degC to 0kJ/kg at the "critical point".
The correct reference document is a set of Steam Tables, available in many engineering textbooks and probably on the 'net as well.
03/13/2007 12:21 PM
Re: Latent Heat of Water
03/13/2007 11:51 PM
144 BTU/lb to change water to ice at 32 dF
970 BTU/lb to change water to steam at 212 dF at atmos press
from my head
Kris (1); Mikerho (1); OLD F**T (1); PWSlack (2)
