Previous in Forum: Which Field is Better   Next in Forum: Difference Between Filter and Strainer
11 comments
Shot Radius Ell
10/20/2010 12:43 PM
please tell me the short radius socket weld elbows center to center distance formula in any degree short radius elbow
Good Answers: 61
Re: Shot Radius Ell
10/20/2010 2:35 PM
Lesson # 1
The terms Long Radius and Short Radius refer to Butt-Weld Elbows
Lesson #2
Socket Weld Elbows and Screwed Elbows do not come in Long Radius and Short Radius.
Lesson #3
Go on the Internet and look up a Pipe Fitting Manufacturer (pennUSA or equal) and you will find answers to your question.
Do it once and do it right
Re: Shot Radius Ell
10/21/2010 3:11 AM
but i need to 45' short radius socket weld Ell center to center distance formula to calculate the spool dimension have u any table and formula plz give me
Re: Shot Radius Ell
10/20/2010 3:58 PM
For butt-weld ells: short, r = D; long, r = 1.5D; "3R", r = 3D.
Re: Shot Radius Ell
10/21/2010 2:26 AM
Good Answers: 137
Re: Shot Radius Ell
10/21/2010 9:07 AM
GOTO #2
Good Answers: 61
Re: Shot Radius Ell
10/21/2010 11:20 AM
Okay lets try this again.
Lesson # 1
The terms "Long Radius" and "Short Radius" ONLY refer to Butt-Weld Elbows
Lesson #2
Lesson #3
Go on the Internet and look up a Pipe Fitting Manufacturer (www.pennUSA.com or equal) and you will find answers to your question.
Lesson #4
I cannot answer your question because you did not give a size for your pipe
Lesson #5
I cannot answer your question because you did not give a "Class" or "rating" for the fittings you are talking about
Lesson #6
I cannot answer your question because Socket Weld 45 degree Fittings do not come in Short Radius.
What part of this do you not understand?
Re: Shot Radius Ell
10/23/2010 3:44 PM
thanks my dear if a 1 1/2" 45' 3000# elbow than what is formula of spool measurement
Good Answers: 61
Re: Shot Radius Ell
10/23/2010 4:07 PM
I am confused! What do you mean by "formula for spool measurement"?
Is it possible that you really mean "The minimum distance between the centerline of two 45 degree fittings"?
If that is correct then the minimum distance center to center of two 1 1/2" 45 degree class 3000 Socket-weld Ells is based on the length of the nipple (say 3") plus 2 "F" dimensions (for the 1 1/2" 45's) from "Tornado's" Chart. The nipple can be almost any length as long as you can still make proper fillet welds.
Re: Shot Radius Ell
10/21/2010 11:51 AM
How about this?
http://www.redoxinc.com/s_dimen2.htm
(I'm not sure if this is a universal standard or just one manufacturer's dimsneions.)
Re: Shot Radius Ell
11/05/2010 2:47 PM
Dam send me your spool sheets and I'll figure them out for you I only have two handfuls of hair to pull until I am totally bald! Wow!
Re: Shot Radius Ell
11/05/2010 2:49 PM
I'm back, if you are using socket weld don't forget to calculate slip back in the socket.
Codemaster (1); iwantu2pk (3); PennPiper (3); pipeit (2); Tornado (2)
