Previous in Forum: Warpage   Next in Forum: Calculate Cylinder
Moog Hyd Valves
10/21/2010 4:07 PM
hey...I have a 4 moog valves on a machine that seem to leaking a small amount. I've checked o-rings, valve block, and temp. of fluid. all appear to be in good condition. I was wondering if I needed to check the bar/psi of said valves and install inline flow controls; because the valves have none installed on them. If there any other points I can check please tell me. thank ya
MattJohnson
Re: moog hyd valves
10/21/2010 5:35 PM
Are you speaking of internal leakage, such as from one passage to another in a spool valve? (As distinct from external leakage through O-ring, chevron, or other seals.) From my understanding--correct me if I'm wrong--spool valves cannot be made absolutely immune to internal leakage, whether from tiny clearances or scoring from fine particles.
I don't know, but I imagine there are specialty control valves that can take care of this.
Re: Moog Hyd Valves
10/22/2010 6:05 AM
its leaking between the vavle body and the block.... its just a tiny bit, but a leak is a leak
MattJohnson
Good Answers: 183
Re: Moog Hyd Valves
10/22/2010 8:56 AM
Chech the o-rings and the block surface and how the bolts have been tightened. If you use the valves (I presume servo or proportional valves) at a higher pressure it is possible to have such surprises since the bolts extend more and the pressure between seal an surfaces is not any more sufficient. Check also if the O -rings do not have a too important permanent set. Where does the leak come from: from the A/B orifices or from the P orifice ? Do you have high pressure changes in the motors (cylinders or rotary motors) an oil "creep" a kind of "pumping" can occur. This has been proved by experiments.
Re: Moog Hyd Valves
10/22/2010 10:22 AM
well this forum appears to have been for nought. at our mill the operators do theyre maint. on the machines and when a big problem occurs we get called in. i have always felt that was huge mistake, cause im trained in feilds they are not. anyways back to leak I took valve down and found a double o-ring causin g the separation on the valve block therefore creating leak. everything you all have said has been helpful and i thank you!
MattJohnson
Register to Reply 4 comments
MattJohnson (2); nick name (1); Tornado (1)
You might be interested in: Check Valves, Gas Valves, Hydraulic Valves
