Previous in Forum: Moog Hyd Valves   Next in Forum: Socket Weld Reducing Tee or Reducer Availability
21 comments
Calculate Cylinder
10/21/2010 11:05 PM
hi, all
how to compute the cylindrical if i have 10 inch dia x 1000mm length into m3
Good Answers: 19
Re: calculate cylinder
10/21/2010 11:19 PM
easy . first make out the area in sft. then x by 6.2 if uk gals then convert to m3.
Good Answers: 181
10/21/2010 11:38 PM
Homework question? It looks very much like it
10/21/2010 11:43 PM
V = πr2h; 1" = 0.0254m.
10/22/2010 12:31 AM
Lemme add furhter to what Torando has said.
where π= 22/7 = 3.14
r=radius= 5inch in this case = 5x.0254m
h=height=1000mm=1m
Always convert all variables in one unit before you multiply to ensure you do not commit conversion mistakes. ............ All the Best.
10/22/2010 12:42 AM
The purist in me compels me to note that π ≠ 22/7 ≠ 3.14. However, π ≈ 22/7 ≈ 3.14.
10/22/2010 1:02 AM
hi, all
254 x 3.1414 x 1000 = ???
convert the volume to cu.M
Reply Score 1 for Off Topic
Good Answers: 97
10/22/2010 1:33 AM
Confused ??
No it is not 254 x . . . . . .
it is the square of th radius (127 mm) x . . . . . .
To estimate your answer to compare , 12.7 cm square x 3.14 is about 500 cm ²
and that is about i litre for 2 mm
10/22/2010 1:37 AM
Could you elaborate further. In my opinion, academically: -
π = 22/7 ≠ 3.14
However, from engineering point of view two decimal places is more than enough for any calculation unless it is to decide on the ICBM trajectory or things similar to that.
Good Answers: 97
10/22/2010 1:42 AM
Why not use 355 / 113 (=3.1415) instead?
10/22/2010 2:02 AM
No, π ≠ 22/7 (It is irrational, and moreover transcendental.)
22/7 = 3.142857142857... (the 142857 repeating forever).
π ≈ 3.141692653... (nonrepeating decimal), so 22/7 is off by more than 0.001.
This is not a matter of opinion, academically or otherwise.
Good Answers: 181
10/23/2010 10:42 AM
MS Excel gives it as 3.14159265358979. But there again if you've waited for Windows minutes to tick by who's counting.
10/23/2010 1:47 PM
Sorry, my misprint. At least the main point remains the same.
Good Answers: 97
10/22/2010 1:55 AM
I was just wondering if it is 10" (250mm) nominal , ID or OD .
Good Answers: 181
10/22/2010 3:58 AM
Has someone dragged a bathtub in to here without anyone noticing?
Where's Del?
Re: Calculate Cylinder
10/22/2010 11:26 AM
The Pi here really sucks.
Reply Off Topic (Score 6)
10/22/2010 3:23 PM
π ×(5 × 0.0254)2 × 1.000, on a calculator.
10/22/2010 10:54 PM
hi, all
3.1416/4 x ( 10" dia ) x 1000mm = ??? cu.M
regard's
MathLab
10/22/2010 11:04 PM
You forgot to convert the inches diameter to meters, and then you forgot to finish the erroneous arithmetic.
Good Answers: 19
10/23/2010 8:56 AM
Sorry , an area of a cyliber is
diameter (in) x length(in) x 3.142 + 2 ( 3.142 X d2/4)/144 = FT2
10/23/2010 6:12 AM
Good Answers: 19
10/23/2010 9:01 AM
why are you gone????
Reply to Forum Thread 21 comments
admeraj (2); Anonymous Poster (3); ducon (3); Hendrik (3); TonyS (3); Tornado (6); woodygb (1)
