Previous in Forum: Bushings & Inserts   Next in Forum: Flanges
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
Nomal Flow vs Rated Flow (Related to BEP)
10/22/2010 5:52 AM
Dear all,
Just curious, what is the meaning of normal flow and rated flow in pump?
One more thing, if i see API 610 Paragraph 5.1.14: "Preferred Operating Region is 70 to 120% of BEP. Rated Flow shall be within region of 80-110%."
What does it mean? Which one should i take? Preferred operating region at 70-120% or Rated flow at 80-110?
Thanks..
Please give respectful & positive answer than insulting! Respect each other ok..
Re: Nomal Flow vs Rated Flow (Related to BEP)
10/22/2010 12:48 PM
Not very clear about the question.
Preferred operatiing region = normal flow ie the flow at which the pump will be usually operating.
Rated flow = designed flow (what has been used by the designer) and will be almost the worst condition where the pump will operate,
As per 5.1.15 the BEP must preferably lie somewhere between those two (and that is common sense too). The other two % are the guide lines but this is the principle.
Based on the basic data you calculate the designed Op Point. Then try to calculate the normal operating point (which may not be very accurate and may vary over time due to wear outs etc). Select the pump such that the BEP is falling between the two
UD15
10/22/2010 3:18 PM
I suspect the two sentences of the API spec apply to two different people. The full rating of a pump would include its curve, but the mfr is allowed to state a single gpm/head rating within 80-110% of BEP. The end user is given more latitude, 70-120%, partly because it may be difficult to estimate actual operating conditions any closer than that.
10/24/2010 10:04 PM
Ok guys thanks for your response.. I have got quotation from vendor, it tells us that ratio of normal flow and BEP is 72%. And i think it is within the range that API stated (70-120%)
Any additional information will be appreciated to be heard.. Thanks..
Register to Reply 3 comments
Anonymous Poster (1); Premium (1); Tornado (1)
