Previous in Forum: Bode Plots   Next in Forum: Selection of MCCBs for Jet Fuel Hydrant Starters
Cost Calculation - Generator Consumption
11/03/2010 12:34 PM
How to calculate Generator cost consumption by Kwh. Generator capacity 30KVA and per hour 115L diesel consumption at 80% load, any bady can send formula for that, pls
Re: Cost Calculation - Generator Consumption
11/03/2010 2:32 PM
115 L/h seems awfully high for 80% of 30 kva.
The genset probably does not run at 80% all the time; you may need to determine what the load profile is over time. The genset data may give specific fuel consumption at various percentages of full load, so that you can sum up (integrate) the fuel usage. If not, a rough estimate would be fuel usage proportional to load.
11/04/2010 12:55 AM
Dear Guest,
It will be around 8 to 9 lts / hour @ full load. Your wording should be
(1) per Kwh and not by Kwh.(2) Generator -Consumption per Kwh.
If you want to calculate the cost per kwh -- (1) Find the Electrical Consumption - meters (2) Find the Diesel consumed & the cost of Diesel (3) Add 2% to the value for lub oil consumed (4) Add the operator cost (5) Find the Total
(5) / (1) will give your cost. At to-days cost one unit will cost anything between
Rs,15 to 17. for lower Capacity sets.
Manroop.chennai.
11/05/2010 4:01 PM
Dear,
I am in Saudi arabia, my negative place in kanyakumari. Our cost of diesel/L 0.25 riyal. Generator will work 75% to 80% load.
If you acn give more idea or formula send to me.
tsyedibrahim@gmail.com
Thanks
11/04/2010 5:24 AM
Take the value of the fuel delivered. Divide it by the time interval between deliveries. This gives an average money consumption rate.
Take the kWh generated and divide it into the same time interval. This gives an average generation rate.
Then divide the one by the other to give money per kWh generated.
"Simples!ξ"
Anonymous Poster (1); manroop (1); PWSlack (1); Tornado (1)
