Previous in Forum: How To Calculate Roll Machining Time?   Next in Forum: Stuctural Angle Load Capacity
9 comments
How to Find Pipe Schedule
11/08/2010 9:53 AM
If anybody know how to find the schedule of an existing pipe where no access is possible to take measurement? the pipe is for water pump suction and discharge.
Re: How to Find Pipe Schedule
11/08/2010 10:02 AM
Oh, how about:
  • Look it up on the P&ID via the annotated Piping Specification for the line.
  • Look it up on the Commissioning Engineer's installation and pressure testing report forms for the line.
  • Look it up in the Validation Technician's Installation Qualification document, if it is in a pharmaceutical factory.
  • Etc., etc.
11/08/2010 10:29 AM
forget to mention first the plant is over 30 years old which means its diffucult to trace one of those mentioned manuels.
11/08/2010 10:36 AM
Not impossible then? Go for it.
11/08/2010 11:00 AM
An ultrasonic thickness detector, perhaps.
Good Answers: 34
11/08/2010 1:08 PM
For what you need this information. Are you going to replace the existing pipe, then only re-calculates it and replace. There is no point where you have access to a flange where you could check the rating?
11/08/2010 2:04 PM
The flange is 1-1/2'' and class 150
does this have a relation with pipe schedule?
11/08/2010 7:17 PM
If the the flange is Welding Neck, you can read the sch on it; because, most flange manufacturer stamp the sch on it, you can assume that the pipe have the same sch unless you are in pressence of high low welding.
Good Answers: 34
11/09/2010 3:12 AM
Yes, go to ASME B31-3 Chapter II.
Wherever, normally, you must have there, Sch 40 (Acocording B35-10 t= 3.68mm) Or STD (According to API 5L t=3.68 mm) for pipe.
11/09/2010 8:16 AM
Is there are way you can take a sample of the pipe in question? What I mean by that is can you possibly cut a section off then take it to a piping distributer then match it up to what they have in stock.
Just a thought.
Neil
Anonymous Poster (3); Farnsworth28 (1); PWSlack (2); Tornado (1); Whitephone (2)
